Old 06-17-2012, 02:04 PM   #1
garage/terrace/i-beam
i have a garage/terrace set up in an old house. needed some structural work and so an I beam was run across the middle of this for support -- architect , engineer the whole thing done right.
Now, i want to put a ceiling in and am not sure how to attach the treated lumber ceiling joists into the steel beam (perpendicularly). this is a 600 sq foot space and i do not want to put any more vertical support , walls, etc.
any help?
crankaroni1 is offline   Reply With Quote
Old 06-17-2012, 02:23 PM   #2
Post some pictures.
Old 06-17-2012, 03:12 PM   #3
Civil Engineer
There are usually many alternatives, you may wish to contact the engineer/architect who did the original design for assistance, since they apparently did an acceptable design job in the first place.
Old 06-17-2012, 03:25 PM   #4
One method would be to drill a few holes and thru bolt a pair of 2x on either side of the web of the I beam. Then use metal joist hangers to attach the joists.
Evstarr is offline   Reply With Quote
Old 06-17-2012, 05:38 PM   #5
as per Evstarr......
garage/terrace/i-beam-mini-scan0089.jpg
tony.g is offline   Reply With Quote
Old 06-18-2012, 03:05 PM   #6
Nice drawing!! Yes!
OSB Stronger than Plywood? Weathermaker01 Flooring 15 12-22-2012 10:06 AM
drilling through steel I beam DIYguy2000 Building & Construction 3 11-21-2011 09:39 AM
How to repair main support beam Jerry48ece Building & Construction 0 01-08-2011 09:38 PM
Main Beam De-Laminating Bird Doo Head Building & Construction 6 12-09-2010 01:08 PM
Beam Replacement? Steve Dailey Carpentry 5 05-19-2008 09:46 PM
