Garage-Stucco Extension Separating From Shiplap - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-01-2011, 10:43 AM   #1
Garage-Stucco extension separating from shiplap
I have a 5' extension on the back of my garage that is separating from the original building. It is 1.5" separated at the top and mostly attached at the bottom. This seems to be mainly due to poor construction - I don't see any other factors. The foundation is in good condition.
The extension is stucco and was added approximately 15 years ago. The original garage is 50 yr old redwood shiplap and currently has aluminum siding over that. (I bought a real fixer-upper!) The original structure appears to be in good condition.
What is the best way to join the extension to the original structure? I am also fixing termite and water damage to the extension, but the solid joining of the structures is my biggest concern.
thanks in advance..
CandiceLynne is offline   Reply With Quote
Weatherproofing garage help Perfik Building & Construction 2 10-17-2012 03:30 PM
Pouring Concrete Slab in a small rickety garage. RORO Building & Construction 0 10-19-2010 03:56 PM
enclosing garage, non-load bearing stucco wall - do I need to cut slab & dig footing? eric559 Building & Construction 3 07-07-2010 01:41 AM
ledger stones on stucco wall, but wall is bowed rrauenza Building & Construction 7 05-18-2010 05:38 PM
Questions about painting and possibly adding siding to stucco house? krm27 Painting 3 01-19-2010 12:22 PM
