-   -   Garage slab pour, Control joint and grounding question (http://www.diychatroom.com/f19/garage-slab-pour-control-joint-grounding-question-104739/)
italie 05-17-2011 10:02 AM
Hello all,
About to finally pour the slab on my "going on 4 months" garage project. Looking for a bit of advice on two items.
I will be pouring a slab inside the existing 10" stem wall perimeter that was poured 4 months ago. Stem wall extends to footers that are 48" below grade. Dimensions are 18' x 30'. Garage is framed, roofed and sided. I've decided on wire mesh sheets as opposed to 3/8" rebar. Availability was more at play in this choice than cost or strength.
Question #1:
I plan on putting in control joints, 1 down the center of the 18' dimension, and two on the 30' dimension. Are these needed on a slab with a frost wall? I've also heard of using metal drywall corner edging underneath the slab to form joints instead of troweling or cutting. Is this a viable option, or just a shoddy short cut?
Question #2:
I was planning on running my electric grounding wire along the rebar until I decided on wire mesh. Can I bond the ground to the mesh as well? If not, I can still drive in a couple grounding rods, I've just heard that a slab ground is preferable to driven rods.
Thanks in advance.
