04-04-2008, 02:46 AM
#1
Garage size.. need opinions!
Hi everyone,
I am planning a garage build this spring, but am stuck on the size I am going to require.
My lot is only 25ft wide, and local code says I have to stay 2 feet from the property line.. leaving me with a whooping 21' maximum.
The second problem is i am going to have to buy a garage package, limiting me to packages that always seem to go to even numbers.. breaking me down to only 20feet wide.
Is this going to work as a two car garage? Our cars are fairly small (Now). I am thinking I might be able to get a larger door to help compensate.. but still don't know how this is going to work out.
I would value the opinion of anyone who'll give it!
04-04-2008, 09:53 AM
#2
gravity always wins
Sounds like the best you can hope for is a 20 foot garage with a 16 foot door. That will work for two cars, just don't plan on trading them in for a pair of large SUVs
04-04-2008, 10:24 AM
#3
I figured SUVs would be out of the question too. I was going to buy a hummer last year.. luckily I went with a smaller rally car.
I do also need to fit a motorcycle in there are well.. so I think I am going to have to go 26 - 28' long to fit the bike and a workspace.
Wish I had a larger space to work with!
04-04-2008, 11:25 AM
#4
Get rid of one of your cars, then you'll have plenty of room for the motorcycle and the workspace without the garage having to be so ridiculously deep.
Steve
04-04-2008, 03:00 PM
#5
Originally Posted by thirstbuster
Hi everyone,
I'm suprised local code doesn't also limit the % of lot you can cover with structures.
04-04-2008, 04:06 PM
#6
That would be a nice option... the wife probably isn't going to walk to work though. And the motorcycle is only good for 6 months a year up here.
Unless your a sadist.. then you can squeeze another month on each side.
If I had the room I'd consider a team of husky's and a sled..
04-04-2008, 05:35 PM
#7
You talking to me?
You need to re-check your measurments to be sure. The setback is from the furthest point out of the buildig, which in most cases is the eave. (or even the gutter if installing one)
if you have a 1 foot eavr overhang and need a 2 foot setback, the largest you could build would be 19 feet wide. There are some structures without any eave overhang but personally, I would use an eave overhang.
04-04-2008, 06:55 PM
#8
Why????????? If your concern is the roof you can stick frame or order trusses any length you need.
I hate 16' doors but that's probably the best choice here. It'll be ok if you have small cars. Go as deep as you want for workspace.
If the 2' setback includes the overhang of the eaves then go with an eaveless design.
04-04-2008, 08:22 PM
#9
I am going to have to double check, but according to people I've talked to, they say I should be able to do 20' with a 1' overhang.
Any smaller than a 20' wide garage would pretty much eliminate the whole project for me... I live in a high-crime city, so I need to fit all my vehicles in there for security as much as anything else.
Anyone have creative ideas for storage etc. in the ceiling of a finished (insulated) garage? I am thinking of lumber etc. Would really love a loft, but I think that's out of my price range.
04-05-2008, 08:49 AM
#10
You talking to me?
who are "the people"?
If they aren't the building inspector/issuer of permits/head poobah of the building department/ grreat gazoo of the zoning department, their opinions don't count.
I can't tell you what your locality requires but I can tell you that if I had a 25' wide lot where I am at and had a 2' setback, a building with 1 foot overhangs could only be 19' wide including the eavestrough, if used. The 2' setback is absolute and means there is absolutely nothing within 2 feet of the property line.
No trying to be argumentative, merely trying to impress the point of checking with the proper authorities before you get too far into the planning.
as far as storage; attic storage trusses are a possibility. Here is an example. They must be built with a floor load designed in.
Be careful of heighth restrictions in your area. You may also look into a car lift or such if you can build a tall enough structure.
 Something like this would allow you to stack vehicles IF you have enough headroom.
04-05-2008, 09:46 AM
#11
In way over my head.
You could try to get a variance to encroach on the property line.
You'll never be sorry you bought the best.
04-05-2008, 04:38 PM
#12
Yes, the "they" is people at a lumber supply store, so I will definitely have to check with the proper professionals. The biggest problem is that every time I contact the City, depending who I talk to I get different answers - and they won't give me anything official in writing.
The store that I was dealing with for the "package" (it isn't prebuilt, but they get all the lumber together and basically give me free delivery and the engineering plans for my permit).
An encroachment is an interesting idea. If I could put a 24x24 garage I would be happy as could be. There are a few in my neighbourhood that size, and the lots are all the same width.. but no one I've talked to actually built their own - it was an existing structure with the property.
It seems to me that the standard height for the garage was something like 13'9" (??) but there are ways to build higher. I have been seeing some very tall garages poping up in my area. Stacking cars, although it is an interesting option, would probably be very expensive and a real pain since they are both daily drivers.
I also need to get more information on garage security packages to tie in with the monitored house alarm.. any suggestions?
04-05-2008, 06:39 PM
#13
You talking to me?
for daily drivers, yes, not the answer.
expensive? Not neccessarily. My godfather built a 3 down 3 up stacker for $400.
So, how long is the lot? Not that it is overly attractive, a longer garage where you could park the cars staggered would help alleviate the narrow situation and having to open doors when parked. You would not even need to park them completely past each other. The front of one and the trunk of the other could overlap but that would still allow door opening.
04-06-2008, 10:03 AM
#14
The lot is 25x125'. I need to have a min. 5' offset from the alley, but I am going to go 6 for good measure, and that should also leave me enough room to park a car on the approach behind the alley.
I think long is how I am going to have to go. It should be that strange looking since the garage is going to be taking up the entire lot.
04-07-2009, 12:12 PM
#15
Planning your garage design on graph paper is a great method (Perhaps the best) to ensure your vehicles will fit and the design will fit your needs. Working with an architect may also be recommended after you understand the design desired. Another quick method when beginning the planning of your new garage plan is to simply use a garden hose / lumber and a tape measure to layout your size before working with your garage building contractor. http://www.GaragePlansforFree.com is a great source of garage building plan designs for free which can help you size your new building to your lot. 20' wide seems to crowd your lot... be sure to talk with your local building inspector and ask for recommendations Perhaps a 20x24 building or a 20x30 size? 20' is about as small in width as you want to go for a 2 car garage.
Hope this helps!
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
