I am planning a garage build this spring, but am stuck on the size I am going to require.
My lot is only 25ft wide, and local code says I have to stay 2 feet from the property line.. leaving me with a whooping 21' maximum.
The second problem is i am going to have to buy a garage package, limiting me to packages that always seem to go to even numbers.. breaking me down to only 20feet wide.
Is this going to work as a two car garage? Our cars are fairly small (Now). I am thinking I might be able to get a larger door to help compensate.. but still don't know how this is going to work out.
I would value the opinion of anyone who'll give it!
Sounds like the best you can hope for is a 20 foot garage with a 16 foot door. That will work for two cars, just don't plan on trading them in for a pair of large SUVs
Get rid of one of your cars, then you'll have plenty of room for the motorcycle and the workspace without the garage having to be so ridiculously deep.
You need to re-check your measurments to be sure. The setback is from the furthest point out of the buildig, which in most cases is the eave. (or even the gutter if installing one)
if you have a 1 foot eavr overhang and need a 2 foot setback, the largest you could build would be 19 feet wide. There are some structures without any eave overhang but personally, I would use an eave overhang.
I am going to have to double check, but according to people I've talked to, they say I should be able to do 20' with a 1' overhang.
Any smaller than a 20' wide garage would pretty much eliminate the whole project for me... I live in a high-crime city, so I need to fit all my vehicles in there for security as much as anything else.
Anyone have creative ideas for storage etc. in the ceiling of a finished (insulated) garage? I am thinking of lumber etc. Would really love a loft, but I think that's out of my price range.
If they aren't the building inspector/issuer of permits/head poobah of the building department/ grreat gazoo of the zoning department, their opinions don't count.
I can't tell you what your locality requires but I can tell you that if I had a 25' wide lot where I am at and had a 2' setback, a building with 1 foot overhangs could only be 19' wide including the eavestrough, if used. The 2' setback is absolute and means there is absolutely nothing within 2 feet of the property line.
No trying to be argumentative, merely trying to impress the point of checking with the proper authorities before you get too far into the planning.
as far as storage; attic storage trusses are a possibility. Here is an example. They must be built with a floor load designed in.
Be careful of heighth restrictions in your area. You may also look into a car lift or such if you can build a tall enough structure.
Something like this would allow you to stack vehicles IF you have enough headroom.
Yes, the "they" is people at a lumber supply store, so I will definitely have to check with the proper professionals. The biggest problem is that every time I contact the City, depending who I talk to I get different answers - and they won't give me anything official in writing.
The store that I was dealing with for the "package" (it isn't prebuilt, but they get all the lumber together and basically give me free delivery and the engineering plans for my permit).
An encroachment is an interesting idea. If I could put a 24x24 garage I would be happy as could be. There are a few in my neighbourhood that size, and the lots are all the same width.. but no one I've talked to actually built their own - it was an existing structure with the property.
It seems to me that the standard height for the garage was something like 13'9" (??) but there are ways to build higher. I have been seeing some very tall garages poping up in my area. Stacking cars, although it is an interesting option, would probably be very expensive and a real pain since they are both daily drivers.
I also need to get more information on garage security packages to tie in with the monitored house alarm.. any suggestions?
expensive? Not neccessarily. My godfather built a 3 down 3 up stacker for $400.
So, how long is the lot? Not that it is overly attractive, a longer garage where you could park the cars staggered would help alleviate the narrow situation and having to open doors when parked. You would not even need to park them completely past each other. The front of one and the trunk of the other could overlap but that would still allow door opening.
The lot is 25x125'. I need to have a min. 5' offset from the alley, but I am going to go 6 for good measure, and that should also leave me enough room to park a car on the approach behind the alley.
I think long is how I am going to have to go. It should be that strange looking since the garage is going to be taking up the entire lot.
Just a curious question. Do they sell these lots specifically for garages? Sounds like an odd size lot for anything else but a 'Nawlins shotgun' style house.
You guys are thinking too hard. Get rid of all of the cars, pick up a couple of used Harley's - maybe a three wheeler for the old lady, plus give her a snow suit fer Xmas and you'll have plenty of room for a workshop AND a bar in a 18' wide x 22' deep garage.
Just throwing in my 2 cents. If you can't go for overall width, I would certainly consider inside height with a loft or eiling storage. I don't like the look of extra tall doors but I have been in some garages with ceiling space I would kill for.
As for depth, if you are in a cold zone, indoor work space is nice. Do the graph paper layout and then look at vehicle lengths (your future vehicles)on the internet. You always want at least 6" behind a vehicle so add that as well. Odds are at least one vehicle you drive now will be upgraded within 3-5 years. Two vehicles with a bike across the front of one only leaves you enough width for a small workbench in front of the other car depending on where your entry door is.
If I could do mine from scratch I would want at least 6' between the edge of the bench and the front of each vehicle.
If you keep the door to the side of the building the end wall may be more functional as work bench or shelf space. Don't forget the beer fridge.:thumbsup:
Good subject. I'm building one right now and find the 20x20 works well for size and convenience. I am starting to put the garage door now and went with a 16x7 size. So I have 2 feet on each side to work with. Here are a couple of pics on what I started. Hope this helps.
Related Threads
DIY Home Improvement Forum
3.1M posts
319.5K members
Since 2003
