Garage Sill Plate Set Directly On Slab. Raise The Garage? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-05-2016, 07:37 AM   #1
Lavid2002's Avatar
Rewards Points: 85
Garage sill plate set directly on slab. Raise the garage?
Hey everyone,
My garage was built with the 2x4 sill set directly on the monolithic slab. When I weed whack the vinyl siding is getting chewed up, and I know when it rains there's moisture the sill is resting on and soaking in.
Any suggestions for this?
All I can think of is raising the garage and building a 1 or 1 block wall around the perimeter of the slab.
Lavid2002 is offline   Reply With Quote
Old 07-05-2016, 07:50 AM   #2
Rewards Points: 2,424
Re: Garage sill plate set directly on slab. Raise the garage?
The yard should have been graded with the garage area a few inches higher than the surrounding yard.
How about adding a walkway around the garage with the required grading, this allows water to run away, and keeps weeds from growing next to it.
ED
de-nagorg is online now   Reply With Quote
Old 07-05-2016, 07:51 AM   #3
Rewards Points: 14,020
How much work you willing to do to fix this?
One sort of simple way is to remove the three bottom rows of siding, remove and replace any rotted sheathing making sure none of it is below grade.
Water proof the sheathing with Storm and Ice Shield, then Install 5/4 X 8" PVC lumber with Z molding over the top of it them J molding.
If you set the PVC at the right height it will run past the slab at least 1" and the siding will not have to be ripped.
I premark where the bottom lap falls on the outside corners then install the PVC about 1/4 to 3/8" below that to have room for the Z and J molding.
garage slab?? Master Brian Concrete, Stone & Masonry 16 07-19-2015 08:53 PM
Replacing sill plate on slab buit garage KathrynCecelia Carpentry 1 05-19-2014 05:42 AM
Garage Insulation yamster Insulation 0 07-01-2011 01:30 PM
Replacing Rotten Sill Plate Material Tester Carpentry 6 03-28-2011 08:08 PM
replacing rotted sill plate and rim joist behind a deck ledger board tommyt Building & Construction 2 08-11-2008 07:38 PM
