Garage/Shop Renovation - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 09-09-2010, 04:28 PM   #16
Totally screwed together
OK, That makes ALOT more sense!
Don't use plastic - if you want a cheap vapor barrier, use tar paper instead. I think you need to install the foam on the exterior face (down to a couple inches off the ground. You would cover that with tar paper, then cover that with vertical 1x material. You would reattach your siding to that 1x material.
That gives you a thermal break, a vapor barrier, and a rain screen to keep your wall dry.
xxPaulCPxx is offline   Reply With Quote
Old 09-09-2010, 10:44 PM   #17
awesome! thank you.
Let me just get this straight... From the exterior to interior it would be: siding, then foam board, then tar paper, then framing with fiberglass insulation?
Or: siding, tar paper, foam board, framing?
inlovewithohio is offline   Reply With Quote
Old 09-10-2010, 01:09 AM   #18
It would be this:
  1. Siding
  2. Furring/air gap (1x material)
  3. Tar paper
  4. foam board
  5. studs
  6. insulation
  7. drywall
Old 09-19-2010, 05:51 PM   #19
Thanks A Lot! Everything is working out, but now to tackle electric...
The original wiring. (See Crude Attachment)
Is this even safe? Legit? two lines running off of one?
I want to take your advice (PaulCP) and upgrade to 12 gauge. And also add a 50 amp breaker for a welder.
Again I have: table saw, miter saw, router, several power hand tools.
(eventually a lathe, band saw, and so on.)
Suggestions? Thanks again!!
Garage/Shop Renovation-current_wiring.jpg
Old 09-19-2010, 10:36 PM   #20
Take another look inside that Junction box.
From your illustration, you make it seem like there are white neutral wires running from the hots.
Now, you CAN have several wires coming off of one circuit. For instance, say one of those 15 amp lines went into the junction box. Inside the junction box, it got wire nutted to four new hots, each going to an individual light switch, it could even have a short hot going to another bundle of four or five wires nutted together. There would be similar tieups for Neutral and Ground for all those lights. All OK - you just need to make sure the box is large enough for how many wires are running in and out.
Using a Junction Box this way is a way of being organized and keeping your breaker panel clean, while still being able to make new connections easily on a whim.
That 30AMP breaker powering the 12ga wires is a problem though. It might have originally fed a motor tool, like a 240v tablesaw for instance. But running outlets of a 30 amp breaker is a big no-no. The wire and outlets will heat up and catch fire BEFORE the breaker will trip!
Here is a pic of my junction box:
Old 09-19-2010, 11:39 PM   #21
That looks amazing! Great organization!
- So I should NEVER run outlets to a 30 amp breaker?
- How will I justify that for a 50 amp if I power an air compressor or a welder?
- What size amp breaker should I use for the outlets that will carry the tools? I want to run 12AWG for those, correct?
I'll be using the existing 14 AWG, on the 15 amp for lighting.
Sorry for the redundant questions, but I'm just trying to understand all of this correctly.
Old 09-20-2010, 10:39 AM   #22
You should never run 15/20 amp outlets (the normal wall style) off a 30 amp breaker. You can put a 30 amp outlet on there though - this is what a regular electric clothes dryer would use for instance. An air compressor might be able to use that same 30 amp circuit too, I don't know. It depends on the tool. Check your wires though, a 30 amp circuit requires 10ga. wire. You cannot plug a regular appliance (say a clock radio) into a 30 amp outlet, the plug won't fit.
If you need 50 amps for an outlet, place a 50 amp breaker in the panel and run the correct size wire (8ga. I think) through your J-box and out to wherever you plan to place your outlet(s). You could put a couple of 50 amp outlets in some convenient spots around your workshop and run them all off one breaker. Unless you are running a production facility, it's unlikely you will be running a 240v welder AND a 240v table saw at the same time. Just remember to turn off the air compressor if it's on that circuit!
That is correct, 12ga. wire is what you need for 12 amp outlets. You should also run at lest two separate circuits around the garage, and alternate the outlets. This way if you run one two tools close together, you can keep one from drawing too much on the same circuit. For instance, I have a small tablesaw and I sometimes hook my shopvac to it as a dust collector. I keep them on seperate circuits so they don't draw eachother down when starting up.
Old 09-27-2010, 04:56 PM   #23
Wiring update! Need help and caution
I detailed all the wiring as much as I could. Here is a diagram. I am going to call an electrician, but i would like to hear what you have to say because you have been so much help!
Wires change, gauges change... It has 10 gauge in the garage box, but the wiring in the house to somewhere outside seems to be 12 gauge or under. Very worried, and it's been like this since we've moved in over 10 years ago.
Garage/Shop Renovation-wiring.jpg
Old 09-28-2010, 01:12 AM   #24
Thanks, your illustration is much improved!
The 20amp lines with 12ga. wire all look great, circuit wise. The go underground to somewhere - switch them off at the breaker box to find out where. Do you have underground sprinklers?
As for the 10ga. ... are you sure that both the black and red from the garage box are tied together in that junction box? That doesn't seem right. What amp breaker are they connected to in the box?
Also, you have a black wire that doesn't seem connected to anything - is that correct?
Old 09-28-2010, 01:20 AM   #25
The black wire is not connected to anything, which IS weird because then it must be hot, yes?
the white wire is just connected to the neutral bar.
Yes, the black and red wire that go into the garage box ARE in fact tied to one red wire.
As far what's happening underground... I don't know. They never had sprinklers though.
I feel as though I need to update though. To a double pole 30 in the house? and a heavier gauge wire to the garage box? and maybe even an updated garage box?
Old 12-01-2010, 11:16 AM   #26
Repost from an additional thread:
Became too busy with person/work life. Had an electrician through the family network come over and run the line while i was out. He ran two #6 as hot, one #8 as neutral and a #10 as ground.
He said all i have to do is buy the 60 amp double pole breaker and a new box for the garage and i'll be set.
now the question... what size box? i need at least 8 spaces.
thanks again for all the help
Old 12-01-2010, 05:09 PM   #27
I used a 20 space 100a panel w/main breaker for my sub
They are only about $26 at HD/Lowes, depending upon Mfg
Tags
electrical , garage , insulation , romex , wiring
Complete renovation Curb Feeler Remodeling 18 08-24-2010 05:46 PM
Basement Renovation Planning: Help! navi_jen Plumbing 0 06-16-2010 09:41 AM
Bathroom renovation Quadfam4 Project Showcase 19 10-15-2009 10:29 AM
The long, dark road of renovation. Curb Feeler Introductions 1 02-03-2009 01:47 PM
Basement renovation - insulation question Jack13 Building & Construction 4 03-01-2008 07:01 PM
