Garage/Shop Conversion Into Living - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-30-2014, 08:24 PM   #1
Apprentice
Question
Garage/Shop conversion into Living
Hello,
I have a 22' by 21' area that was originally a 2-car garage and was partially finished, converted into a shop.
The previous owners did the following:
  • Removed Garage Door
    Added Brick Wall w/ few windows
    Installed Carpet Floor
    Added studs to block walls
    Added some plywood
    Some insulation
    Drywall on ceiling
I plan on completely finishing the room, but I have a few questions.
My plan so far:
- Remove studs attached to block wall
- Leave a space from wall and do new 2x4 framing
- Re-do wiring
- Insulate
- Drywall
HVAC: Mini Split unit
I've been reading the forums and have a few questions:
1- How do I frame around the elevated areas (mainly close to the doors)
2- What to do with the current carpet flooring? (would like to keep it)
3- Any other input/suggestions?
PS: Sorry for the mess, everything will be leaving the area soon.
Last edited by BigJim; 05-02-2014 at 07:35 PM. Reason: Pictures removed per OP's request
DSee is offline   Reply With Quote
Old 05-01-2014, 02:32 AM   #2
Residential Designer
AndyGump's Avatar
Rewards Points: 662
Send a message via Skype™ to AndyGump
If you are in an area of Mass. that requires permits you will need plans for it.
The plans should outline what you need to get it done so it is reasonably safe to occupy.
That is why god created designers.
I am too busy so don't ask me.
Andy.
Andy
Residential Drafter/Designer
www.draftinginoc.com
AndyGump is offline   Reply With Quote
The Following User Says Thank You to AndyGump For This Useful Post:
DSee (05-01-2014)
Old 05-01-2014, 07:37 AM   #3
JOATMON
ddawg16's Avatar
Rewards Points: 1,116
Like Andy said.....you need permits.....if you get caught without one....chances are, you would have to rip it all out....and pay a hefty fine.
The Following User Says Thank You to ddawg16 For This Useful Post:
DSee (05-01-2014)
Old 05-01-2014, 07:37 AM   #4
Apprentice
Andy.
Andy
Thanks for the input.
I will be using the space as an entertainment area, more like a mancave.
Old 05-01-2014, 07:39 AM   #5
Apprentice
Any comments on the questions I asked above regarding the framing around the elevated areas, and what to do with the carpet floors (thinking about cutting the edges and leaving it as is)
Old 05-01-2014, 09:19 AM   #6
landfillwizard's Avatar
Rewards Points: 502
Before you do anything, find out if permits were given for previous remodeling by the former owner.
landfillwizard is offline   Reply With Quote
The Following User Says Thank You to landfillwizard For This Useful Post:
DSee (05-01-2014)
Old 05-01-2014, 10:58 AM   #7
Apprentice
Noted. I will contact the building department and ask to see the permits history.
Thanks.
Old 05-01-2014, 03:01 PM   #8
GBrackins's Avatar
Rewards Points: 2,108
is the carpet installed on the concrete slab or did they install a wood flooring system?
if concrete is the floor sloped towards the previous location of the garage door?
what part of Mass may I ask? I may have experience in that area.
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
The Following User Says Thank You to GBrackins For This Useful Post:
DSee (05-01-2014)
Old 05-01-2014, 05:06 PM   #9
Apprentice
1- I pulled some of the carpet to take a look, and it looks like it was installed on concrete slab (on top of some padding).
2- The floor is level everywhere, with exception of the 2 door entrances (1 goes to basement, other to "tool storage area")
2a- It seems like there's a "cement ramp" towards the door, as you can see in the pictures.
3- Bristol County.
Now the questions I'm debating with are:
- Should I just replace the entire carpet? (I would rather not, as this was not included in my budget)
- How do I frame around the sloped door entrance (see 2nd pic)
I can provide better pictures if needed.
Thanks again guys.
Garage/Shop conversion into Living-1.jpg   Garage/Shop conversion into Living-2.jpg
Hot house, living room only bigpaws HVAC 2 12-04-2011 08:28 AM
Living room arrangement challenge... r3yrey Interior Decorating 5 05-16-2011 02:22 AM
garage conversion into living space with bedroom brookendarren Building & Construction 3 12-15-2010 11:00 PM
Suggestions for Living Room gante Interior Decorating 3 03-06-2009 12:56 PM
