Garage Roof Insulation Between Rafters - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-21-2009, 11:36 AM   #1
garage roof insulation between rafters
Hi all, I've searched a bunch of garage insulation posts but haven't found an answer to my situation.
I just had a 24x22 detached garage built at my home in Denver, CO. I don't plan on heating the garage with anything other than a small space heater but would like to fully insulate. I have insulated and sheetrocked the walls of the garage and am now thinking about the garage roof.
There is definitely no soffit venting and I don't believe there is ridge venting but I could be wrong. The garage is a 5/12 gable with 2x8 rafters at 24" o.c. I don't want to enclose what would be the attic portion and insulate on top of a ceiling. I want to insulate between the roof rafters and ideally leave this area exposed. For this reason I don't want to use batts.
Is there a rigid insulation product I can use that will be somewhat decent looking on the exposed side while not creating a fire hazard? Obviously fire hazard is relative.
Second question, do I need to vent even though the roof will remain exposed on the inside?
Thanks for your help all.
denverman71 is offline   Reply With Quote
Old 10-21-2009, 12:06 PM   #2
ArmchairDIY's Avatar
I hate to disappointed you, but foam insulation should not be left exposed it is a fire hazard and most likely would be a code violation.
As for ventilation, if you insulate a building you should also provide a means of ventilation. Granted it is a garage and not heated all the time, but none the less it also has potential for condensation issues when it is being heated.
ArmchairDIY is offline   Reply With Quote
Strange Winter Roof Leak Dragon Roofing/Siding 16 10-09-2009 06:06 PM
Garage Door Insulation Kit diyDude_2 Remodeling 2 01-15-2009 11:51 PM
Flat roof questions, advice, ballpark estimate JerryH Roofing/Siding 18 11-07-2008 04:08 PM
Changing Pitch over roof. tying into house rafters? EnlightMent Roofing/Siding 3 03-27-2007 12:16 AM
