Garage Remodel Footings - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-01-2009, 09:00 PM   #1
garage remodel footings
We have just purchased a forclosure and wanta build in our attached garage. We want to raise the floor to the same grade as the rest of the house. My question is do i need to put a footing where the garage door was?
James schroder
james schroder is offline   Reply With Quote
Old 09-01-2009, 09:58 PM   #2
Framing Contractor
James schroder
You shouldn't have too because the footings always go there at least where I'm from.
Joe Carola
Joe Carola is offline   Reply With Quote
Old 09-01-2009, 10:30 PM   #3
Registered User
Rewards Points: 526
You should check with your local Building Department. They may require all foundations to be below the frost depth.
Generally the garage footings are shallower than the house's, as per use. There may be egress needs (bedroom), light (window) and ventilation requirements as well. The fill-in at the garage may need special shear framing, especially if an older garage. Most City/County B.D.'s have a web site to check on such, or just give them a quick call to be safe. I encourage a permit as the next buyer will look for that on your house's personal County record. Your Homeowners Insurance is more likely to cover a claim, if permitted also.
Be safe, G
Garage Wiring issues jimmyfloyd Electrical 20 06-08-2009 02:57 PM
new double garage murray1426 Building & Construction 4 05-23-2009 01:11 PM
Garage ceiling and attic storage DIY KEN Building & Construction 7 01-06-2009 04:57 PM
Garage remodel concrete lip jlaumark Remodeling 1 09-28-2008 02:45 PM
Garage remodel Russell Carpentry 8 11-10-2005 11:16 PM
