Garage Remodel, Drywalling Around Obstructions - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-14-2010, 06:10 PM   #1
garage remodel, drywalling around obstructions
I am installing drywall in a garage that doesn't currently have drywall. There is wiring, water & gas pipes that were run in front of framing which makes drywall impossible. Rerunning the wiring and pipes is not an option. I've seen sometimes pipes are run on the surface of drywall, but that must have been done after drywall is up. I don't see how drywalling behind pipes is possible. So what options do I have now? I can either drywall up to the pipes and leave the framing in the area with pipes exposed, or soffit it?
Another obstruction is the garage door hardware. How do I install drywall around that? Does the drywall normally go between the framing and the hardware?
acerunner is offline   Reply With Quote
Old 09-14-2010, 11:08 PM   #2
My garage door hardware goes on top of the drywall. I think for a garage it's best to have everything sealed with fire-code drywall and tape, especially the ceiling if there is living space above. Can you frame around the pipes?
kwerk is offline   Reply With Quote
Old 10-01-2012, 05:17 PM   #3
dmojahed's Avatar
Hi,
This is an old thread but curious to know the path you took to resolve. In addition to what you stated I've thought of furring the wall studs but that is a lot of work. So, unless I hear an alternative, I'm likely to do a soffit. In my sitiation the conduit and gas line are straight shots along the wall and they are 6" apart.
Cheers!
Darius
dmojahed is offline   Reply With Quote
garage remodel footings james schroder Building & Construction 2 09-01-2009 11:30 PM
Drywalling Garage zpm Building & Construction 7 07-31-2009 02:20 PM
Garage Wiring issues jimmyfloyd Electrical 20 06-08-2009 03:57 PM
Drywalling garage ceiling: joist hangers protruding rdy2go Building & Construction 2 04-19-2009 08:30 AM
Garage remodel Russell Carpentry 8 11-11-2005 12:16 AM
