Garage Remodel - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 01-07-2013, 05:05 PM   #16
GBrackins's Avatar
Rewards Points: 2,092
it would be a cathedral ceiling, you'd need to make sure the wall separating the garage from the dwelling is properly covered according to the table. Of course you cannot simply remove (well you could but you wouldn't like the results) the ceiling joists. If you are planning on a remodel I'd recommend involving a knowledgeable designer to help you out with it. A cathedral ceiling typically would require either a structural ridge beam or rafter ties (installed in the lower 1/3 of the space between the ridge and top of walls) at a minimum of 48" o.c. to prevent the rafter trust from pushing out the tops of the load bearing walls, which in turn causes saddling (bowing) of the ridge.
Sorry about the mix up, I thought you asked Joe about VA. if you edited your profile to include your location it would help in providing you with more useful information. Here is a link for the building codes in Texas. http://www.reedconstructiondata.com/...g-codes/texas/
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
The Following User Says Thank You to GBrackins For This Useful Post:
BigJim (01-07-2013)
garage remodel, drywalling around obstructions acerunner Building & Construction 2 10-01-2012 04:17 PM
MWBC to Garage Questions benleef Electrical 3 02-22-2012 11:02 AM
Garage Ceiling Remodel ?? What is this board? Julieanna Building & Construction 1 09-19-2009 07:31 AM
Raising up my garage jimmyfloyd Building & Construction 5 09-17-2009 10:39 PM
garage remodel footings james schroder Building & Construction 2 09-01-2009 10:30 PM
