Garage Rafter Ties - Can I Remove Them? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-27-2010, 03:07 PM   #1
cmj
Garage Rafter Ties - Can I remove them?
Hi Guys,
I have a 18X20 attached garage that had 3 2X4 collar ties running the 20' span as well as 3 rafter ties about half way up the pitch. I just removed the collar ties and intalled 2X6 joists 16"o.c. along the 20' span, with a beam running the 18' span. Is it safe to remove the 3 remainig 1"X2" rafter ties?
cmj is offline   Reply With Quote
Old 01-28-2010, 07:02 AM   #2
IMHO, you should not have removed anything. The collar ties keep the walls from spreading outward. The rafter ties keep the roof from sagging in the middle.
Old 01-28-2010, 08:40 AM   #3
Where are you located ?
Do you have a picture ?
I think your terminolgy is off
Rafter ties keep the walls from spreading
If you removed 2x4 rafter ties & installed 2x6 not a problem
Even better since there were only 3 before & now you have rafter ties every 16"
Why do you want to remove the collar ties ?
Old 01-28-2010, 06:17 PM   #4
cmj
Ok, I guess my terminology is off a little bit. I had 3 2x4 20' joists/rafter ties on the top plate. I removed the 3 2x4s and replaced them 2x6 joists and installed a beam, halving the 20' span. I still have 3 1x2 collar ties about half way up the peak, can I remove those?
Old 01-29-2010, 07:35 PM   #5
For what reason, would you want to remove these? Do you need head-room?
Old 01-29-2010, 11:11 PM   #6
Registered User
Rewards Points: 4,936
1. Where are you located? CA or FL and a lot of others, you will need special ties for high wind or seismic areas.
2. How many nails and what size did you use at the rafter/joist, and laps over the new beam? (solid blocking?)
3. 1x2's, are you sure?
4. Rafter ties are required every 4', so you should have had 4.........
Be safe, Gary
Old 02-02-2010, 11:57 AM   #7
cmj
1. I'm in California
2. I'm not sure how many nails my contractor used to attach the joist to the rafter. The joists lay on top of the beam and are toe nailed, I'm thinking about adding 90 degree straps. The rafters also have blocking throughout.
3. They might be 1x3 or 1x4
4. The house was built in the 50's and there are only 3.
I'm not planning on storing much weight up there, but I might add some insulation between the rafters as a radiant barrier. The peak is only about 4.5", so it would be much easier to move around while I'm doing this if the collar ties where removed.
Cutting rafter ties ?? scatkins Building & Construction 23 04-13-2010 04:20 PM
Rasing rafter ties and Venting Question. Does AtlanticWBConst. Still Frequent? gregt848 Building & Construction 11 09-24-2009 09:46 PM
Garage subpanel installation - EMT ScottR Electrical 26 06-11-2009 01:53 PM
Basement Garage with Concrete Slab: To Vent or not to Vent N-GA-Homeowner Remodeling 3 05-29-2009 07:13 AM
Mold in detached garage jkrodger Building & Construction 15 05-01-2009 02:46 PM
