Garage Rafter Is Split...repair?? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-05-2012, 10:04 PM   #1
Garage Rafter is Split...repair??
New homeowner here...
Just found out one of the rafters in my garage attic is split in the middle and causing issues with the ceiling drywall.
The drywall touches the overhead gas supply, and i figured it was due to nail pops- i started screwing up the ceiling and now you can really see the problem. My concern is the rafter is falling on each side of the split- and I do not want it to fall and break the gas line. How/Should this be fixed?
thanks for the help!
Garage Rafter is Split...repair??-rafter-split.jpg   Garage Rafter is Split...repair??-garage-gas-line.jpg   Garage Rafter is Split...repair??-ceiling-hitting-gas-line.jpg
duster7286 is offline   Reply With Quote
Old 07-05-2012, 10:20 PM   #2
Rewards Points: 14,014
Looks like a ceiling joist not a rafter.
Looks like someone cut it.
Your going to have to sister another one next to it, full length would be best.
Use constrution adhesive and screws to attach it.
Old 07-05-2012, 10:33 PM   #3
AHH, SPANS!!!
Rewards Points: 1,166
If there is access to get a new joist into the attic space that will work best. raise up what is there with temporary bracing against the ceiling in the room below and install the new joist in the attic..
hand drive is offline   Reply With Quote
Old 07-06-2012, 07:08 PM   #4
thanks for the advice! Sorry about my incorrect terminology
Old 07-07-2012, 08:34 PM   #5
Registered User
Rewards Points: 526
I'd sister the new one on some 1/2" shims at bearing points to get the broken one on the same plane as the rest. This will give you "wriggle room" to get it exact or plus a hair so it is level after removing the bracing.
Gary
Garage Roof Rafter Question bobwoz Building & Construction 0 08-30-2011 03:31 PM
Is tape necessary to repair holes in drywall (in garage)? Scotch99 Drywall & Plaster 4 08-22-2011 01:08 PM
Garage door asthetic repair dkmb Building & Construction 6 04-15-2011 07:48 PM
Large Concrete Crack repair - detached garage. alecmcmahon General DIY Discussions 3 09-12-2010 08:07 PM
Help Repair Garage Wall - Advice RandomJustice Building & Construction 8 07-28-2007 10:02 PM
