Garage Pull Up Bar - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-29-2012, 05:06 PM   #1
Garage pull up bar
Have 23' 2x9 d-fir ceiling joists in my garage. The joists are braced with plywood that runs the length of the garage.
I recently installed the pull up bar (pic below) using 3/8" bolts with cut washers and nuts.
I weigh approximately 208lbs. I was thinking that I might add an additional 2x6 brace from the joist to the truss above on the right side of the pull up bar.
Any thoughts / suggestions on how to do so would be appreciated.
starkhd is offline   Reply With Quote
Old 02-29-2012, 09:34 PM   #2
Registered User
Rewards Points: 5,514
I would attach a 2x on top the joists, run perpendicular to the joist/rafter, then attach the bar to that. You would be distributing any weight on two different joists and not have the tipping load as there is now.
Gary
Old 03-01-2012, 05:42 AM   #3
Rewards Points: 1,580
Why not bridging between the rafters to reduce tipping instead of moving the bar?
bob22 is offline   Reply With Quote
The Following User Says Thank You to bob22 For This Useful Post:
kj6887 (03-01-2012)
Old 03-01-2012, 08:06 PM   #4
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,200
bridging between the bottom chord of the truss wont be as strong as gbr's idea. by going with 2x on top of the bottom chord you accomplish the same thing as the plywood but have more meat to fasten the chinup bar too.. the bolts or screws are more likely to pull out of the plywood than 2x
woodworkbykirk is offline   Reply With Quote
Old 03-02-2012, 07:36 PM   #5
How much joist deflection do you get when you yank yourself up? How 'bout when you're just hanging there?
Old 03-02-2012, 08:49 PM   #6
The deflection when i pull up is noticeable, but doesnt seem severe.
unconditioned garage reillyoevans HVAC 3 08-20-2011 06:29 PM
Garage remodel - adequate foundation? WillK Building & Construction 1 01-21-2011 01:50 PM
Can I pull my own wire and install outdoor coachlights on my garage? If so - how? Michael C. Electrical 2 12-20-2010 06:52 AM
Garage Ideas? tripflex General DIY Discussions 13 12-16-2009 07:06 PM
Garage Ventilation Question eagle09tbl HVAC 5 10-22-2009 09:24 PM
