Garage Mudroom Wall Composition - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-05-2009, 09:35 AM   #1
garage mudroom wall composition
Hello, our garage is longer (not wider) than we need and we don't have a mud room. I'm building a 10' x 6' mudroom in the back corner. It's not really an exterior wall but I'd like to insulate it like crazy since the garage is the outside temp and I'd like to be able to leave the door to the mudroom open. Can anyone recommend a specific wall construction? Currently I'm thinking 2x4 with batts in the cavities, rigid foam board, housewrap, then drywall. Would that work? If that's not crazy, how would I attach the drywall through the foam board to the studs?
jutah is offline   Reply With Quote
Old 01-05-2009, 09:42 AM   #2
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Sheetrock should always be installed directly against framing/or some other hard surface (not over foam). If you are planning on insulating the wall, then you should install the insulation in the framing cavities.
- Build Well -
Old 01-06-2009, 10:23 AM   #3
Thank you for the response. Would this work for a wall then (from inside mudroom to garage): drywall, plastic vapor barrier, 2x6 wall with insulation in cavities, house wrap, garage side drywall. Is tyvek or other housewraps not considered to create a double vapor barrier?
Old 01-06-2009, 05:33 PM   #4
Originally Posted by jutah View Post
....Would this work for a wall then (from inside mudroom to garage): drywall, plastic vapor barrier, 2x6 wall with insulation in cavities, house wrap, garage side drywall.
There is no need for housewrap, because the interior garage wall will be protected from outside weather.
AS mentioned, there is no need for the house wrap. This material is primarily a sub-layer of protection from exterior weather elements. Since the inside of your garage won't be experiencing heavy rains, snow, wind, etc.....there is no need for it's use there.
- Build Well -
Considerations when pouring concrete against a stucco wall? clint_nichols Building & Construction 9 09-24-2009 05:28 AM
Mold in detached garage jkrodger Building & Construction 15 05-01-2009 01:46 PM
Garage ceiling and attic storage DIY KEN Building & Construction 7 01-06-2009 04:57 PM
Removal of interior wall Bobb G Remodeling 4 09-15-2008 01:30 PM
Replacing Wall in Garage viking1974 Building & Construction 3 08-10-2007 10:23 PM
