Garage Leaking Into Basement - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-31-2009, 01:19 PM   #1
shuship's Avatar
Garage leaking into basement - please help
please offer advice on how to fix. Currently, basement is unfinished and I plan to finish (at least this area in question) by this Spring. Went down this am and noticed this problem. As far as I can tell, its coming from the joints of the concrete pads in the garage. The snow (in central Ohio) that has been carried in on my car tires, has melted and is leaking down the wall into this part of the basement. Do I caulk this area in the garage? Do I drylok this part of the wall? Both? The current temp in the basement is @59 deg F with a RH @ 30% - at least according to my Oreg. Sce. Hygrometer. Any ideas of what to do to eliminate this happening in the future as best as possible would be great.
shuship is offline   Reply With Quote
Old 01-31-2009, 07:28 PM   #2
shuship's Avatar
pics from inside garage
Do I caulk this edge?
Garage leaking into basement-01-31-09_garage-floor-leak_0004.jpg   Garage leaking into basement-01-31-09_garage-floor-leak_0005.jpg
Garage Door Leaking webweever Building & Construction 2 10-26-2008 04:04 AM
advice on cold water pipe in basement garage area cambie Plumbing 6 10-15-2008 02:29 PM
Basement Garage, Jackposts? OW3Canuck Building & Construction 7 06-26-2008 09:35 PM
Water leaking into basement johnjpas34 Building & Construction 2 09-06-2007 06:28 PM
2nd refrigerator - garage or basement hermansherman Appliances 4 12-18-2006 05:48 PM
