Garage Insulation Question - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-19-2006, 02:01 PM   #1
Rewards Points: 14
Question
garage insulation question
I live in North Dakota and am looking at insulating, sheetrocking, and heating a detached garage. What type of insulation would I need to use? What rating would I need?
bigbrad123 is offline   Reply With Quote
Old 05-19-2006, 08:25 PM   #2
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Hi,
I don't live in North Dakota, but where I live, the minimum insulation required for a heated garage is R-13. It is not going to be used as a living space/area, so the requirements aren't the same as in a home.
If you have 2x6 walls, use R-19.
If you really want to keep the place warm, you can go with an R-30 for the ceiling joists. R -30 isn't cheap on the costs.
My 2 cents from New England
Old 05-20-2006, 12:42 AM   #3
renovations
I'm in W. Canada, and we too would use R-19 in the walls (2x6).As much as you can afford in the ceiling. You can add more later, too, if you like. As a reference, here, in a home it is required to have R-40 in the ceiling. Don't forget to vapour barrier on the "warm-in-winter" side of the insulation before the sheetrock..
Bonus is offline   Reply With Quote
Old 05-20-2006, 06:34 AM   #4
at your local hardware store, they should know and stock the r-value you will need. i would use the rolled with vapor barrier flanges. whats youe email address? i will send u a pic of my garage job.
THEBIGPUNN is offline   Reply With Quote
Old 05-21-2006, 01:50 PM   #5
Rewards Points: 14
Thanks for the advice. I haven't priced anything yet, but hope to soon.
Insulation question hswaters General DIY Discussions 9 12-28-2008 09:18 PM
Rigid insulation question Endeavor General DIY Discussions 2 07-17-2007 11:27 AM
Question about ceiling joists in a garage allpraisebob Carpentry 11 12-14-2006 09:00 AM
yet another insulation question bobbyhill Building & Construction 2 12-06-2006 01:01 PM
insulation question steele Building & Construction 4 05-15-2006 09:24 PM
