-   -   garage insulation question (http://www.diychatroom.com/f19/garage-insulation-question-2537/)
bigbrad123 05-19-2006 01:01 PM
I live in North Dakota and am looking at insulating, sheetrocking, and heating a detached garage. What type of insulation would I need to use? What rating would I need?
AtlanticWBConst. 05-19-2006 07:25 PM
Hi,
I don't live in North Dakota, but where I live, the minimum insulation required for a heated garage is R-13. It is not going to be used as a living space/area, so the requirements aren't the same as in a home.
If you have 2x6 walls, use R-19.
If you really want to keep the place warm, you can go with an R-30 for the ceiling joists. R -30 isn't cheap on the costs.
My 2 cents from New England
Bonus 05-19-2006 11:42 PM
I'm in W. Canada, and we too would use R-19 in the walls (2x6).As much as you can afford in the ceiling. You can add more later, too, if you like. As a reference, here, in a home it is required to have R-40 in the ceiling. Don't forget to vapour barrier on the "warm-in-winter" side of the insulation before the sheetrock..
THEBIGPUNN 05-20-2006 05:34 AM
at your local hardware store, they should know and stock the r-value you will need. i would use the rolled with vapor barrier flanges. whats youe email address? i will send u a pic of my garage job.
bigbrad123 05-21-2006 12:50 PM
Thanks for the advice. I haven't priced anything yet, but hope to soon.
