Old 11-11-2009, 01:58 PM   #1
Garage Insulation
When insulating an unheated garage should I use a vapor barrier? I will use kraft faced on the ceiling so I can staple it in place prior to hanging my drywall but what about the walls?
Jim Hart is offline   Reply With Quote
Old 11-11-2009, 02:38 PM   #2
Average Joe/ex-Navy IC3
gregzoll's Avatar
Garage Insulation
If it was me, I would go with the vapor barrier, since you never know when you may want to use for other stuff (ie Guy cave, studio, body work). The better you can keep the cold from coming in during the Winter, the better you can keep it heated if you have to work for more then a couple of hours in the space.
gregzoll is online now   Reply With Quote
Old 11-11-2009, 05:13 PM   #3
Moderator
Garage Insulation
I definitely would! That stops the warm, moist air from rising off the car and getting the new insulation wet. Be sure to ventilate the roof above the insulation. Drywall will only slow it down with a permeability of 40. I would also use one of the paints listed, to stop the water at the surface of the drywall: http://www.panhandleinsulation.com/b...materials.html
Be safe, Gary
Clothes taking longer to dry?
Old 11-12-2009, 08:44 AM   #4
Garage Insulation
Thanks for the advice. I'll use a vapor barrier, a good paint and yes, the attic is well ventilated.
Garage Door Insulation DIYguy2000 Building & Construction 11 12-15-2009 05:00 PM
garage roof insulation between rafters denverman71 Building & Construction 1 10-21-2009 01:06 PM
Garage insulation question trojanman1 Building & Construction 7 09-16-2009 03:51 PM
Insulation questions for new detached garage mpt1123 Building & Construction 2 03-01-2009 09:18 AM
Garage Door Insulation Kit diyDude_2 Remodeling 2 01-16-2009 12:51 AM
