Garage Framing - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-16-2013, 10:58 AM   #1
Rewards Points: 396
Garage framing
The area in front of the garage opening where you pull your car in that is on the same grade as the slab in the garage is there a foundation wall in that area as well like the rest of the perimiter of the garage or is it just only brought up to grade level?
detroittigerfan is offline   Reply With Quote
Old 08-16-2013, 11:45 AM   #2
GBrackins's Avatar
Rewards Points: 2,108
the answer to your questions depends on your building code requirements.
typically in my area we have a foundation wall under all sides of exterior walls with the footing at least 48" below the adjacent grade for frost protection (frost heave).
typically the concrete floor slab is thickened to 8" (typical 4" slab) where is goes over the foundation wall.
hope this helps. good luck!
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
Old 08-16-2013, 01:46 PM   #3
Rewards Points: 396
So, the front of the garage where the doors are don't have foundation walls? If so, the garage door headers have to be supported all the way down to foundation so I take in the front of the garage there are foundation walls only in the area of the header supports (trimmers)?
Old 08-16-2013, 03:23 PM   #4
GBrackins's Avatar
there is foundation typically all across the front
Gary
Old 08-16-2013, 03:41 PM   #5
Rewards Points: 396
ok, and the slab for the enterance covers the foundation wall. For a 3 car garage I see sometimes the foundation wall coming up and splitting part of the garage like one half is the 2 car area and the other is 1.
Old 08-16-2013, 03:54 PM   #6
GBrackins's Avatar
if the top of foundation comes above the concrete floor slab then the top of foundation will drop below the slab where the doors are. in my area we drop the top of foundation 8" below the top of slab where the doors are located. in the other areas the top of foundation is typically about 12" above the slab.
hope this makes sense
Gary
Old 08-16-2013, 04:15 PM   #7
GBrackins's Avatar
there are many ways to construct a garage foundation, but this is typical for my area
Gary
Old 08-16-2013, 09:36 PM   #8
firehawkmph's Avatar
Rewards Points: 1,898
DTF,
here's a pic of what it should look like. Block and brick are up 12" above top of cement slab. You can see what the door openings look like. Below are block and footers down to 44" below grade.
Mike Hawkins
firehawkmph is offline   Reply With Quote
The Following 3 Users Say Thank You to firehawkmph For This Useful Post:
GBrackins (08-16-2013), Willie T (08-18-2013), Windows on Wash (08-16-2013)
Old 08-18-2013, 07:57 AM   #9
Rewards Points: 396
Originally Posted by firehawkmph View Post
DTF,
Mike Hawkins
So, the slab in the door openings are basically sitting on the foundation wall that is not exposed? Is there an air space between brick and foundation wall?
Old 08-18-2013, 08:02 PM   #10
Old School
Willie T's Avatar
We typically have a 4" to 6" slab here, "belled" (haunched) on the garage side at 45°, 12" down from garage FF, with a flush vertical outside wall where the driveway will eventually go. Often one #5 across there. There's a full footing beneath that is a running continuation of the overall perimeter footing.
There's a recessed door step-down, of course.... usually 1/2" with 1/4" slope outward in 8"..... About what Mike's photo shows. A lot of people recess the door opening 3/4", but I have found that makes a fairly grievous "tripping" hazard... 1/2" is bad enough.
Willie T
Old 08-18-2013, 08:24 PM   #11
Old School
Willie T's Avatar
Now, here's a pretty clever way to do the door apron. Don't know what's under there, as this one isn't mine. But I like getting that joint line out away from the garage door.
Notice, also, that the "step-down" starts a few inches back inside the interior wall line? That's important, depending on how your door hangs, and where it hits the floor. It also needs to be a few inches wider than the actual opening width... if the door is behind the opening, and not just sitting between the walls. (check where your particular door footprint will fall.)
Mike's takes care of that particular detail with the bricks being extended past the blocks. This one has "wrap-around" bricks that return back in toward the garage, all the way to the inside edge of the blocks.
Willie T
Old 08-19-2013, 08:14 AM   #12
Rewards Points: 396
So, again is there a footing and foundation wall even where the garage door entry is because your not seeing the wall there?
Old 08-19-2013, 01:21 PM   #13
Maryland
This was answered several times. Yes.
Pittsville is offline   Reply With Quote
Old 08-19-2013, 03:22 PM   #14
Rewards Points: 396
no it was not answered..
Old 08-19-2013, 03:29 PM   #15
Maryland
::sigh::
Garage Insulation yamster Insulation 0 07-01-2011 01:30 PM
floor framing in garage chrishallowell Building & Construction 0 06-29-2010 08:04 AM
Thoughts on wiring new attached garage/hallway Mi Feller Electrical 45 06-18-2010 06:47 PM
garage door framing Please help craigcr Carpentry 4 10-18-2009 10:55 AM
Garage Framing Question wrldruler Building & Construction 5 08-22-2008 08:26 AM
