-   -   Garage framing (http://www.diychatroom.com/f19/garage-framing-185374/)
detroittigerfan 08-16-2013 10:58 AM
Garage framing
The area in front of the garage opening where you pull your car in that is on the same grade as the slab in the garage is there a foundation wall in that area as well like the rest of the perimiter of the garage or is it just only brought up to grade level?
GBrackins 08-16-2013 11:45 AM
the answer to your questions depends on your building code requirements.
typically in my area we have a foundation wall under all sides of exterior walls with the footing at least 48" below the adjacent grade for frost protection (frost heave).
typically the concrete floor slab is thickened to 8" (typical 4" slab) where is goes over the foundation wall.
hope this helps. good luck!
detroittigerfan 08-16-2013 01:46 PM
So, the front of the garage where the doors are don't have foundation walls? If so, the garage door headers have to be supported all the way down to foundation so I take in the front of the garage there are foundation walls only in the area of the header supports (trimmers)?
GBrackins 08-16-2013 03:23 PM
there is foundation typically all across the front
detroittigerfan 08-16-2013 03:41 PM
ok, and the slab for the enterance covers the foundation wall. For a 3 car garage I see sometimes the foundation wall coming up and splitting part of the garage like one half is the 2 car area and the other is 1.
GBrackins 08-16-2013 03:54 PM
if the top of foundation comes above the concrete floor slab then the top of foundation will drop below the slab where the doors are. in my area we drop the top of foundation 8" below the top of slab where the doors are located. in the other areas the top of foundation is typically about 12" above the slab.
hope this makes sense
GBrackins 08-16-2013 04:15 PM
1 Attachment(s)
there are many ways to construct a garage foundation, but this is typical for my area
firehawkmph 08-16-2013 09:36 PM
1 Attachment(s)
DTF,
here's a pic of what it should look like. Block and brick are up 12" above top of cement slab. You can see what the door openings look like. Below are block and footers down to 44" below grade.
Mike Hawkins:)
detroittigerfan 08-18-2013 07:57 AM
Originally Posted by firehawkmph (Post 1230273)
DTF,
Mike Hawkins:)
So, the slab in the door openings are basically sitting on the foundation wall that is not exposed? Is there an air space between brick and foundation wall?
Willie T 08-18-2013 08:02 PM
We typically have a 4" to 6" slab here, "belled" (haunched) on the garage side at 45, 12" down from garage FF, with a flush vertical outside wall where the driveway will eventually go. Often one #5 across there. There's a full footing beneath that is a running continuation of the overall perimeter footing.
There's a recessed door step-down, of course.... usually 1/2" with 1/4" slope outward in 8"..... About what Mike's photo shows. A lot of people recess the door opening 3/4", but I have found that makes a fairly grievous "tripping" hazard... 1/2" is bad enough.
Willie T 08-18-2013 08:24 PM
1 Attachment(s)
Now, here's a pretty clever way to do the door apron. Don't know what's under there, as this one isn't mine. But I like getting that joint line out away from the garage door.
Notice, also, that the "step-down" starts a few inches back inside the interior wall line? That's important, depending on how your door hangs, and where it hits the floor. It also needs to be a few inches wider than the actual opening width... if the door is behind the opening, and not just sitting between the walls. (check where your particular door footprint will fall.)
Mike's takes care of that particular detail with the bricks being extended past the blocks. This one has "wrap-around" bricks that return back in toward the garage, all the way to the inside edge of the blocks.
detroittigerfan 08-19-2013 08:14 AM
So, again is there a footing and foundation wall even where the garage door entry is because your not seeing the wall there?
Pittsville 08-19-2013 01:21 PM
This was answered several times. Yes.
detroittigerfan 08-19-2013 03:22 PM
no it was not answered..
Pittsville 08-19-2013 03:29 PM
::sigh::
