Garage Foundation - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-06-2009, 02:32 PM   #1
Rewards Points: 768
Garage Foundation
If we convert our single car garage to a bedroom/bath can we build on the existing slab? We'll have to build a new floor to allow for plumbing and a level floor.
Secondly, does the garage need a foundation or will the current slab (which looks to be in good condition..a couple cracks on the exterior, but nothing on the interior) work for the space?
Finally, what is the best way and easiest way to determine if the current garage has a foudation?
cibula11 is offline   Reply With Quote
Old 08-06-2009, 04:06 PM   #2
Concrete & Masonry
Rewards Points: 470
I've worked on a few remodels were this was done.
If the garage is currently attached to the house, it should already be on a similar foundation as the house. Obviuosly, this needs to be verified.
The best & easisest way is also the only way I know of: grab a shovel.
jomama45 is offline   Reply With Quote
Old 08-07-2009, 08:45 PM   #3
Rewards Points: 768
That's kind of what I figured. Thanks. I think the house and garage are the same age, so I would think it has a solid footing. I guess I'll get my shovel
Old 08-07-2009, 11:34 PM   #4
Rewards Points: 1,016
Converting a garage into livable space is something you should work with your building department and pull a permit. Some areas are very strict on garage coversions.
Not saying it can't be done - but it should be done properly to ensure you don't have problems down the road with unpermitted work, being able to claim the square footage when you sell, etc.
Old 08-08-2009, 12:10 PM   #5
Rewards Points: 768
I'm well aware of my need to contact local building dept. I know for a fact that converting a garage is not an issue where I live because there are several houses with in a few blocks that have done this. Two of them are currently on the market. You can tell that these conversions have been done by professionals.
I just wanted to know if given there is no footing or foundation like the house, if a conversion can still be done.
Old 08-08-2009, 02:36 PM   #6
Registered User
Rewards Points: 4,924
Probably not or maybe. . All walls need footings to transfer the loads down to the earth. Your local B.D. would tell you if the slab area between garage jambs needs one or not. Be sure to contact your Insurance Company at permit time to be covered for any unforeseen problems. This is not the answer you want but it is entirely a local thing, how they interpret the minimum safety code. I did one and had to engineer the front header opening wall, pour a footing and short wall (pinned to the side foundation stem walls), with special shear wall nailing on the wood wall above. I left the slab under the new floor joists with a bearing footing cut into it for support. Heat source, egress window, light and ventilation, etc. are also required. Bottom line, we don't know. Be safe, G
Bad garage foundation Red Squirrel Building & Construction 1 07-17-2009 09:19 PM
Garage Foundation "Tilting?" Shane N Building & Construction 8 10-10-2008 11:13 AM
Garage Conversion: Loading Bearing Foundation wrldruler Building & Construction 3 08-26-2008 10:11 PM
Garage foundation seaside Building & Construction 3 09-18-2007 09:51 AM
Garage foundation questions Don-NH Building & Construction 2 04-16-2005 01:03 AM
