Garage Foundation - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-11-2011, 12:11 AM   #1
garage foundation
Didn't now if I had to tar the foundation before I back filled
chief12 is offline   Reply With Quote
Old 06-11-2011, 12:14 AM   #2
Rewards Points: 1,016
Welcome.
More info would help to respond.
Where is the garage located? What type of foundation?
Old 06-11-2011, 12:28 AM   #3
The garage is in P.A. its not attached to the house its four feet in the ground
Old 06-11-2011, 12:28 AM   #4
8 inch block
Old 06-11-2011, 02:01 AM   #5
Rewards Points: 4,454
how sad is this, sheetz ?
you only need to ' tar ' the foundation walls if you don't want water leaking into it then again, can't imagine having a partially underground garage but haven't been in pennsylvania in yrs,,, what did your local bldg dept say/recommend ? IF you would like the wall to last longer w/o bulging, it would be helpful to pour concrete into the cells as block have MUCH less resistance to soil pressure than conc
you wouldn't be using ' tar ' in any event as that must be applied as a hot liquid,,, IF it were mine & i wanted it to last, i would use troweled-on roofing cement & protect it w/hdpe dimpleboard ( miradrain / sonneborn / meadows )
The Following User Says Thank You to stadry For This Useful Post:
vsheetz (06-11-2011)
Old 06-11-2011, 07:25 AM   #6
Framing Contractor
How did it pass inspection?
Joe Carola
Joe Carola is offline   Reply With Quote
Old 06-11-2011, 08:26 AM   #7
Concrete & Masonry
Rewards Points: 470
There's no benefit to damproofing/tarring a 4' frost wall.
jomama45 is offline   Reply With Quote
Pouring Concrete Slab in a small rickety garage. RORO Building & Construction 0 10-19-2010 04:56 PM
Garage Insulation DIYguy2000 Building & Construction 2 12-09-2009 08:41 AM
Garage Wiring issues jimmyfloyd Electrical 20 06-08-2009 03:57 PM
new double garage murray1426 Building & Construction 4 05-23-2009 02:11 PM
