Garage Floor Slope - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-07-2009, 09:41 AM   #1
Rewards Points: 1,910
Garage Floor slope
Getting ready to pour a new garage floor. I need to slope it towards the door. What are the recommended minimum and maximum slopes for a garage floor?
I want to be sure it drains well as there will likely be lots of melting snow coming off the cars and I will be washing cars in the garage at times.
Old 10-07-2009, 09:43 AM   #2
Min slope I was told by my building Dept is 1/4" every 4'
Not sure on a Max, or if there really is one
Old 10-07-2009, 09:59 AM   #3
Concrete & Masonry
Rewards Points: 582
In WI, there is no min. or max. listed in our code.
We usually set for 3-4" total in a normal depth garage.
Anything deeper than 24', we generally leave the back level & only pitch the front 20-24' to the OH doors. This allows a nice level area in the back for fridges, work bench, shelves, etc...
1/4" per foot is excessive IMO, as long as the floor is fairly flat (no deep bird baths), 1" every 6-8' is sufficient.
Keep in mind, the short walls adjacent to the OH door should also have minor pitch (towards the OH) to avoid water pooling in those corners.
jomama45 is offline   Reply With Quote
Old 10-07-2009, 10:16 AM   #4
Rewards Points: 348
1/4" over 4 feet will drain but slowly, much over that and front to rear on a 28 to 30 foot garage is becomes noticeable. This will add cost but if you will have a lot of snow and ice melting off the cars you might want to put a couple of drains in the middle of each bay. Use 1/4 to 1/8 per foot slope to the drains and you will not have a problem. This will keep the salt and dirt off your driveway. Just be sure to install drain basins you can easily clean out with a shovel.
Rege
RegeSullivan is offline   Reply With Quote
Raising up my garage jimmyfloyd Building & Construction 5 09-17-2009 10:39 PM
Garage Wiring issues jimmyfloyd Electrical 20 06-08-2009 02:57 PM
new double garage murray1426 Building & Construction 4 05-23-2009 01:11 PM
Garage ceiling and attic storage DIY KEN Building & Construction 7 01-06-2009 04:57 PM
