Garage Floor Problem - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-22-2011, 07:42 PM   #1
Rewards Points: 91
garage floor problem
I have a 24x24 open carport. Metal roof, wood supports every 8 feet. Supports are 4x6 pressure treated.
I would like to build a floor and eventually enclose area to make a garage type structure.
I have the choice of having a slab poured but I think it will be very expensive. Other option is joists and exterior plywood floor. I have no idea if I need 1/2 ,3/4 or thicker plywood. I know I can use plywood as I considered buying a Handi House, pre assembled garage units with wood floor capable of supporting vehicles. Cost was $4,000 for a 12x24 unit with roll up door, electricals, windows.
Anybody know best thickness aand if my joists should be 18 in apart or closer?
I may get quotes because I really dont think Im up to the task. Think the Handi House would be less expensive?
I really do not want to leave a bare earth floor
Thank you
drjay9051 is offline   Reply With Quote
Old 03-22-2011, 08:15 PM   #2
Rewards Points: 1,016
What is your usage planned to be - vechicle parking, workshop, or ?
What considerations for a building department permit?
Off-hand, I would suggest to pour a concrete floor.
Weatherproofing garage help Perfik Building & Construction 2 10-17-2012 04:30 PM
The 12-Gauge Garage Jack Olsen Project Showcase 28 07-08-2012 11:21 PM
Raising up my garage jimmyfloyd Building & Construction 5 09-17-2009 11:39 PM
Garage Wiring issues jimmyfloyd Electrical 20 06-08-2009 03:57 PM
