Garage Floor - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-17-2011, 12:07 PM   #1
Garage Floor
Can anyone make some suggestions on what to use to finish an old garage floor. It's fairly uneven with a low spot in the center. I would like to level it and have a nice finish. Any help would be appreciated
TonyD
TonyD is offline   Reply With Quote
Old 11-17-2011, 01:43 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Self Levelling Compound.
It takes a particular Self Levelling Compound to produce a wear-surface.
The Following User Says Thank You to Bud Cline For This Useful Post:
TonyD (11-17-2011)
Old 11-17-2011, 03:26 PM   #3
JOATMON
ddawg16's Avatar
Rewards Points: 802
That topic is discussed in significant length over on a Garage web site..."Garage Journal". Do a search...there is one section just for floors.
When I was doing my garage....I found the web site....after reading up on floors, I didn't do anything...for now....
I think you will find the exact info you are looking for over there.
Warning.....DO NOT look at the Garage Gallery.....it will only make you feel bad...
The Following User Says Thank You to ddawg16 For This Useful Post:
TonyD (11-17-2011)
garage floor problem drjay9051 Building & Construction 1 03-22-2011 08:15 PM
Recommendations for finishing garage floor? bhpizza Flooring 30 01-28-2011 11:09 PM
floor framing in garage chrishallowell Building & Construction 0 06-29-2010 09:04 AM
Garage Attic Floor Joists zacmac Carpentry 3 11-02-2009 10:07 PM
