Garage Floor - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-17-2011, 09:42 PM   #1
Garage floor
I am planning on framing a floor my garage and have a few questions.
the garage is 22x11 and attached to my house. I am removing the wall between the house and garage and converting the garage into another room. I want to have a smooth transition from the house floor into the garage.
The garage floor is on a pitched slab. in the rear of the garage the slab is about 5 inches below the interior house floor and on the front of the garage I have about 8 inches.
My thought is to run a level ledger from the back to the front and one in the center of garage from back to front and use 2x4 going left to right and just shim under the 2x4's as the floor pitxhes. On top of the 2x4's I plan on using 3/4 inch tongue and grove ply wood as my sub floor. The garage is going to be one large area but kind of two rooms. In the one section I plan on doing carpet and the other section I was thinking on using 1x8 pieces of pine to make a look alike plank floor.
1. Are the 2x4's ok to use since I plan on shimming
2. How long of a span can I do using that method? Can I do a five foot piece running from ledger to a center ledger?
3. Do in need the sub floor if I am using 1x8 pine planks or can I nail them directly to the 2x4's
4. Any other cheap ideas on what else to use instead of the pine planks?
Thanks!!!
Tomperro is offline   Reply With Quote
Old 07-17-2011, 09:50 PM   #2
Rewards Points: 5,336
Thanks!!!
If you're talking about regular common 1x8's as flooring, I'd think again. The wood is too soft to be used as flooring and will dent in a heartbeat.
Not a fan of shimmed 2x4's as a base for the room either.
Ron
B. Franklin 1759
Old 07-17-2011, 10:00 PM   #3
you need to use 2x8's and trim them where you have to for the slope in the floor. 2x6's are good for 12 feet when used as ceiling joists but not on a floor. where you have to trim the joists for the slope use pressure treated where the touch the floor. 2x4's would be much too springy. you can do it if you want but it wont be pretty when it's done. what do you plan to put in these rooms? if you find engineered flooring on sale it can be cheaper then 1x8 planks
Old 07-17-2011, 11:37 PM   #4
Rewards Points: 1,016
garage conversions typically require permitting - do ensure you go through this importanat step to protect yourself and the value of your home.
____________
Vince
garage floor problem drjay9051 Building & Construction 1 03-22-2011 07:15 PM
Recommendations for finishing garage floor? bhpizza Flooring 30 01-28-2011 10:09 PM
floor framing in garage chrishallowell Building & Construction 0 06-29-2010 08:04 AM
Garage Attic Floor Joists zacmac Carpentry 3 11-02-2009 09:07 PM
