Garage Drainage Ideas.. - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-12-2009, 10:29 PM   #1
Question
Garage drainage ideas..
Hello everyone!
I would like to say that this site is awesome with many helpful people
Since this is my first post and have been looking for an answer to my spring run off issue in my garage, I figured this was the best place to post my question.
I have a 24x23 foot detached garage that was built before I owned the house. Every year during the spring thaw my garage floor gets wet with water. It seeps through the exterior walls due to snow build up. I was thinking of digging a trench around the garage next to the concrete pad and filling the trench with gravel to absorb the run off so it doesn't flood my garage floor. Is this a good idea or should I explore other avenues? Thanks in advance for the help.
Volkstech is offline   Reply With Quote
Old 08-12-2009, 11:57 PM   #2
you could dig a trench and put in some crusher dust and perforated drain tile to divert the water where you want...and if it's on a side where concrete is, you could cut out the concrete and re pour it with a slight pitch to where you want it to go.
ebstein is offline   Reply With Quote
Old 08-13-2009, 06:18 AM   #3
Rewards Points: 4,748
1st, figure out how to stop the melting snow's liquid from entering the walls you may need a sheet OR brush-applied membrane,,, the pipe's a good idea but NO ' crusher dust ' ( its compactible & will plug piping ) - ONLY clean 3/4" stone maybe soil fabric.
remember wtr runs downhill & takes the path of least resistance - right now its finding the garage floor easiest
Old 08-14-2009, 01:34 PM   #4
ooppss..pea gravel would work better.......I musta had crusher dust on my mind.
Old 08-14-2009, 03:01 PM   #5
Rewards Points: 1,016
French drain
http://en.wikipedia.org/wiki/French_drain
Old 08-14-2009, 05:04 PM   #6
Registered User
Rewards Points: 526
More good reading: http://www.awc.org/Publications/DCA/DCA6/DCA6.pdf Did you notice the foam board insulation in one picture? It is to help prevent the water in the drain and around from freezing.
to help prevent frost heaving of your garage walls: http://www.oikos.com/esb/43/foundations.html
Be safe, G
Garage Wiring issues jimmyfloyd Electrical 20 06-08-2009 02:57 PM
new double garage murray1426 Building & Construction 4 05-23-2009 01:11 PM
Garage ceiling and attic storage DIY KEN Building & Construction 7 01-06-2009 04:57 PM
