Old 02-04-2013, 10:32 PM   #1
Garage doors
I want to remove my garage door and I believe it is called a barn style doors. It's the two big doors that open side ways like a front door not up. I am very handy and could make a plain one easy by making a frame and making two 4 foot doors out of a slab of fine plywood but I want to put windows in but not sure how to install them
diemondd47 is offline   Reply With Quote
Old 02-05-2013, 10:53 AM   #2
gravity always wins
Garage doors
If I understand this, you want to remove your overhead garage door and replace it with two hinged doors. And you want to use plywood as a base for the doors. Plywood alone will not make a good door. It will warp all up and will soon start to delaminate. What you need to look at is more like a barn door, which is made from a frame with diagonal bracing that is then covered with some tongue and groove siding. It is possible to frame a window opening in a door like that. The other thing you'll need to consider is whether you have sufficient framing in the garage walls to carry the hinged weight of the doors.
Old 02-05-2013, 11:04 AM   #3
Garage doors
I was thinking the like a solid slab of ply wood order like a butcher block or a 2in solid piece of plywood not the cheap glued together ones the frame is strong enofe
Old 02-05-2013, 11:08 AM   #4
Garage doors
But what u r saying they frame them inside with im guessing like 2x2 then put the finish on the out side of it
Expanding Garage INTO house (goodbye Den) texaopian Building & Construction 16 11-07-2011 11:32 PM
Strengthening Garage Doors JackOfAllTrades Windows and Doors 5 09-13-2011 09:50 AM
Refinishing Garage Doors with Sikkens Cetol 123 AustinPainter Painting 0 08-28-2011 01:54 PM
Swinging Garage Doors Justin08 Carpentry 1 11-16-2008 11:59 AM
