Garage Door "thump" After It Closes - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-25-2009, 01:21 PM   #1
Garage door "thump" after it closes
Whenever I close the garage door (using the garage door opener) and it closes completely, then there's a thump noise about a second or two afterwards. Any idea what would cause this? It does it every time now. It started about a week ago.
proofer is offline   Reply With Quote
Old 11-25-2009, 07:18 PM   #2
Household Handyman
Rewards Points: 1,408
I'll have to ask this: When you close the garage door, and you state that it closes "completely", do you watch the bottom of the garage door to see if it maybe lowers just a wee bit when you hear this "thump"? I'm wondering if the internal "down" setting of the garage door opener/closer is not set just right. The door may be reaching it's "down" position and the closer is shutting off, but the actual door is not all the way down and gravity takes over and the door lowers just that little bit causing this "thump" sound as it closes completely. Watch it closely and let us know. David
Old 12-07-2009, 05:22 AM   #3
Thanks for your response. But it seems, for some reason, to have fixed itself. Maybe it was happening right as the cold weather moved in for the season? I don't know, but it doesn't seem to be causing anymore problem. I'll have to make a note to watch it next year at this time.
Old 12-07-2009, 04:41 PM   #4
Rewards Points: 2,638
Or perhaps the opposite of what Thurman suggested. The bottom of the door stops on the concrete, and a second later, the mechanism stops moving ( possibly excessive play in the mechanism ). I saw this condition eventually fatigue and break the pull mounting bracket on a door once.
SPS-1 is offline   Reply With Quote
Raising up my garage jimmyfloyd Building & Construction 5 09-17-2009 10:39 PM
Garage Wiring issues jimmyfloyd Electrical 20 06-08-2009 02:57 PM
new double garage murray1426 Building & Construction 4 05-23-2009 01:11 PM
Garage ceiling and attic storage DIY KEN Building & Construction 7 01-06-2009 04:57 PM
Garage Door Install marly General DIY Discussions 2 11-17-2008 02:51 PM
