Garage Door Spring - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-09-2009, 03:45 PM   #1
garage door spring
I've got old fashioned garage door springs mounted in the cocrete floor of my garage. An over and under retractable door. 16' x 7'. They are mounted to the vertical tracks by a iron arm. The bolt attaching the spring to the arm broke. How do I re attach? Closed, the other spring is quite stretched it seems.
she8iff is offline   Reply With Quote
Old 12-10-2009, 10:19 AM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,736
Ayuh,.... Got a Picture or 2,...
Visualizing it from your description ain't workin'...
Old 12-12-2009, 10:56 AM   #3
firehawkmph's Avatar
Rewards Points: 1,936
She8,
Not sure by your description what exactly you have. Sounds like a tilting door not a sectional. Whatever it is, most garage door springs are not under very much tension when the door is in the up position. Makes sense right? I have installed quite a few garage doors. Here in Ohio, most are sectional doors with torsion spring setups, some have extension springs on each side. If you are not sure what you are doing, do yourself a favor and call a garage door guy. Too easy to hurt yourself.
Mike Hawkins
firehawkmph is online now   Reply With Quote
Garage Insulation DIYguy2000 Building & Construction 2 12-09-2009 07:41 AM
Raising up my garage jimmyfloyd Building & Construction 5 09-17-2009 10:39 PM
Garage Wiring issues jimmyfloyd Electrical 20 06-08-2009 02:57 PM
new double garage murray1426 Building & Construction 4 05-23-2009 01:11 PM
Garage ceiling and attic storage DIY KEN Building & Construction 7 01-06-2009 04:57 PM
