Garage Door Removal And Replacement - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-13-2008, 05:51 AM   #1
Rewards Points: 35
garage door removal and replacement
I have a older, heavy wood garage door. I need to remove the door for a day. Can I, when the door is open, brace the door, undo the 4 bolts on each side of the door that hold it to the bracket and slide it off? Any spring related surprises to watch for? I assume, since there is no tension on the springs in the door open position, there should not be a problem.
TVC15 is offline   Reply With Quote
Old 08-13-2008, 07:06 AM   #2
Whatamess
There will still be tension on the springs. You can lock the springs using vise grips.Relieve the pressure on the spring using a bar and clamp securely. Do this with the door down. Be very careful if you decide to attempt this.Many people have been hurt working on these doors. You can unhook the cables and take the panels out one at a time. Note these wooden doors are very heavy.
I may go home hungry, but not tired and hungry.
TazinCR is offline   Reply With Quote
Old 08-13-2008, 08:17 AM   #3
47_47's Avatar
Rewards Points: 44
Garage door springs store a considerable amount of energy which can cause serious injuries, call in a pro.
47_47 is offline   Reply With Quote
Old 08-13-2008, 08:49 AM   #4
Registered User
Termite's Avatar
This isn't a DIY project for safety's sake alone. I was on a jobsite right after a carpenter had his lower jaw and face removed by a garage door torsion bar during an attempt to remove it to get at the framing.
Old 08-13-2008, 05:49 PM   #5
I too know of several injuries associated with doors and their springs. Serious stuff even though it looks straight forward. If you don't KNOW exactally what your doing please call a pro. There are about a dozen different spring/door combinations around. You say it's older and heavy, that means your springs are heavy duty too.
Stay safe!
Shamus
Shamus is offline   Reply With Quote
Old 08-13-2008, 06:30 PM   #6
Rewards Points: 35
Is my described technique faulty or, is it always dangerous?
I recall changing springs a few years ago on another garage and all it took was: door was open and braced, 3 guys pulled down on the spring and hooked it onto the bottom chain.
If spring changing is less hazardous I can
1) brace the door open
2) release the springs
3) remove the door
Stanley Garage Door Opener SUNNY General DIY Discussions 5 12-13-2010 10:37 AM
sill replacement or? watchtower7 Building & Construction 5 06-07-2008 04:50 PM
Replacement Meter Panel leonard_voet Electrical 19 04-09-2008 11:27 AM
Garage Concrete Ledge for Door Replacement orangewhip Building & Construction 7 05-22-2006 08:09 PM
