-   -   garage door removal (http://www.diychatroom.com/f19/garage-door-removal-2965/)
fishinAK 07-05-2006 06:39 PM
garage door removal
So I will try to make this brief. Quick question though. So I have a home that is slab on grade. There used to be a garage under the home. I am removing the garage door and putting up a window and a stud wall where the garage door was.
So the question is....do I need to pour a small stem wall the height of the stem wall arond the rest of the home? Or should I just use expansion bolts and bolt a treated piece of lumber directly onto the slab?
I was planning on pouring a stem wall but I am not sure if it would even seal as well as a board directly on the slab. Plus since the origingal header form the garage door is still intact very little weight will be on this footer. If I do need to pour a stem wall is rebar reinforcement nessacary?
Thanks for any and all help!
joasis 07-05-2006 09:49 PM
I have seen hundreds of garages converted to living space doing exactly what you are doing...no stem required. You will get a better seal using the treated sill plate and sill seal or silicone, then you would with a cold joint in concrete.
MrNoMaintenance 07-06-2006 01:12 AM
Just another thought but not to rain on your parade, in Canada there are many municipalities that are not allowing cars to be parked directly in front of living space. They have introduced these types of bylaws for safety reasons and it therefore doesn’t allow most home owners to convert their garage to living space or even widen their driveway to fit another car.
fishinAK 07-06-2006 11:10 AM
thanks for the replys any more?
Wow thanks for the responses guys! So am I to assume that is what most of you would do?
It sure would be easier to simply bolt a piece of treated lumber directly to the slab and not worry about pouring any mud!
so what do you think a 1/2" expansion bolt every 2'? across the 10' doorway?
tribe_fan 07-06-2006 07:09 PM
I had an addition put on a slab - better check the local building codes - mine stated that there had to be "X" amount of both thickness and height of brick - with the bottom board attached to this.
Bonus 07-06-2006 10:57 PM
I'd probably go with the pt wood on the conc. unless: check the slope and the wind. Occasional wind driven rain coming in to a garage is one thing, under your sill is another, you don't want to rely on caulking.
