Old 04-13-2012, 02:52 PM   #1
Garage door opening
I have constructed a corrugated metal building (30Lx25Wx13H). It is free-standing and I am ready to add wood framed end-walls. These, of course, are non-load bearing. I am putting a 16 ft. segmented residential door (nominal weight) at the opening. What size header and framing will I need to span the opening? Thanks for any advice.
pstrulm is offline   Reply With Quote
Old 04-13-2012, 10:45 PM   #2
cortell's Avatar
Garage door opening
Maybe I'm missing something, but if the exterior walls are not load-bearing, why would you need any header above the door?
cortell is offline   Reply With Quote
Old 04-13-2012, 11:16 PM   #3
Garage door opening
Thanks for responding. The wall will be a total of 13 ft. high, obviously 6 ft. above the door opening. So the wall won't be supporting the building, but the framing above the door. I'm just wanting to make sure that a 16 ft. span will be sufficiently supported.
Old 04-14-2012, 06:35 AM   #4
cortell's Avatar
Garage door opening
Ah. Now I understand.
Assuming the top plate of that wall will be fastened to the frame of the building, and that that frame is fairly strong, you're already getting quit a bit of load relief without a header. I would guess that a 2x6 header would suffice. A 2x8 header would be even better, and thats what I would probably go with.
Expanding Garage INTO house (goodbye Den) texaopian Building & Construction 16 11-07-2011 11:32 PM
Garage Insulation yamster Insulation 0 07-01-2011 02:30 PM
Do I have a Fire Rating Issues with Attached Garage Perry401 Building & Construction 4 04-26-2011 12:58 AM
Garage Wiring issues jimmyfloyd Electrical 20 06-08-2009 03:57 PM
