-   -   Garage door opening (http://www.diychatroom.com/f19/garage-door-opening-140185/)
pstrulm 04-13-2012 02:52 PM
Garage door opening
I have constructed a corrugated metal building (30Lx25Wx13H). It is free-standing and I am ready to add wood framed end-walls. These, of course, are non-load bearing. I am putting a 16 ft. segmented residential door (nominal weight) at the opening. What size header and framing will I need to span the opening? Thanks for any advice.
cortell 04-13-2012 10:45 PM
Maybe I'm missing something, but if the exterior walls are not load-bearing, why would you need any header above the door?
pstrulm 04-13-2012 11:16 PM
Thanks for responding. The wall will be a total of 13 ft. high, obviously 6 ft. above the door opening. So the wall won't be supporting the building, but the framing above the door. I'm just wanting to make sure that a 16 ft. span will be sufficiently supported.
cortell 04-14-2012 06:35 AM
Ah. Now I understand.
Assuming the top plate of that wall will be fastened to the frame of the building, and that that frame is fairly strong, you're already getting quit a bit of load relief without a header. I would guess that a 2x6 header would suffice. A 2x8 header would be even better, and thats what I would probably go with.
