Garage Door Opener Rail Flexing - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-14-2013, 02:58 PM   #1
Rewards Points: 60
Garage door opener rail flexing
Put in a Chamberlain PD210 opener on a single piece wooden 2 car garage door. Everything seems to work except the flexing of the rail during opening and closing.
The door is slightly off balanced. The gap on one side is 2x the other. Would that cause the flexing? If so, how to balance the door? It has 4 metal rods with nuts at each end. 2 mounted on the top of the door left to center, and right to center. Same at the bottom of the door.
Will new spring help reduce the flexing?
chhfsc is offline   Reply With Quote
Old 05-14-2013, 05:44 PM   #2
Rewards Points: 13,978
Post a picture.
Old 05-15-2013, 10:11 AM   #3
Rewards Points: 150
When is it flexing? When up, when down, or when in transit?
If the door goes down then the rod flexes, then your down trim is set too far. Vice versa if when up, tho I can't imagine flexing while up.
If it's when in transit, then the door isn't going up smooth. When you unlatch the trolley, do the springs lift it easily by hand? It should go up w/o much effort and stay there at the proper height comfortably. If it doesn't, then it's got to do w the springs and balancing. Experiment more w/o the opener in the picture to figure out if the springs are working optimally.
SquishyBall is offline   Reply With Quote
Old 05-17-2013, 07:21 PM   #4
Rewards Points: 60
Flexing is during transit, going up and going down.
I think is due to unbalance. Manually open and close the door, the door shift to one side during transit.
Any advise on how to balance the door with tightening/loosening the nuts?
Old 05-17-2013, 08:07 PM   #5
Roofmaster
Rewards Points: 2,210
Can you easily lift the garage door with two fingers, and stop it anywhere and it stays there? If you cant, your door is not tracking parallel, or your springs are not properly tensioned. It that bar is flexing the opener is working too hard. A single wooden double wide garage door is heavy. Is it tight and square?
Old 05-17-2013, 10:04 PM   #6
Msradell's Avatar
Rewards Points: 262
If that's the case, the spring force is probably not equal from side to side. The springs will need to be adjusted. If you don't have any experience doing this, you're probably better off having someone else do it. Adjusting the springs can be relatively dangerous because the forces involved.
Msradell is offline   Reply With Quote
Old 05-18-2013, 09:42 AM   #7
MJ Force's Avatar
Rewards Points: 150
If you've never done this before do not try to adjust your spring tension. A qualified service guy can determine if your springs are tired, or undersized, or off balance etc. it's so dangerous to adjust these. Call an expert.
MJ Force is offline   Reply With Quote
Adding subpanel to Garage jimmyfloyd Electrical 2 11-09-2012 09:22 AM
Garage Roof Support & 2nd Floor Addition Info? olimits7 Building & Construction 3 10-15-2012 06:42 PM
Junction box feeding power to garage from house gmbojanowski23 Electrical 4 10-02-2012 10:20 AM
garage door opener rail extension? drtbk4ever Windows and Doors 6 07-17-2012 11:49 AM
Subfeed to New House from Existing Garage??? scuba.man Electrical 2 06-21-2012 07:54 AM
