Garage Door Opener Issue - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-14-2013, 12:50 PM   #1
garage door opener issue
solved
srodie is offline   Reply With Quote
Old 02-14-2013, 01:37 PM   #2
retired union carpenter
Send a message via Yahoo to coupe
If the door does not open completely but opens at
least five feet (1.5 m):
Increase up travel. Turn the UP limit adjustment screw
clockwise. One turn equals 2" (5 cm) of travel.
NOTE: To prevent the trolley from hitting the cover
protection bolt, keep a minimum distance of 2-4"
(5 cm
- 10 cm) between the trolley and the bolt
as always, just my thoughts
good luck....coupe/Larry
take what helps? ignore the rest.
coupe is offline   Reply With Quote
Old 02-14-2013, 02:38 PM   #3
Rewards Points: 1,296
Please don't delete the question you posted. The information in the replies may help someone else with the same problem. What did you find that solved the problem?
danpik is offline   Reply With Quote
Old 02-14-2013, 02:48 PM   #4
I didn't use the adjustment screws on the side of the opener.
Old 02-14-2013, 03:54 PM   #5
Newbie Bill
Rewards Points: 522
Probably embarrased to say they just forgot to plug it in.
Bill
A DIY Noob that knows just enough to be dangerous.
drtbk4ever is offline   Reply With Quote
Tags
garage door opener
Garage door electric eye issue Oh-Fudge Electrical 18 02-05-2013 09:31 AM
In theory: expand attached garage, or add detached garage? hyunelan2 Building & Construction 5 11-09-2012 05:34 PM
Garage door issue! canadianmag1 Windows and Doors 4 06-15-2011 04:50 PM
Do I have a Fire Rating Issues with Attached Garage Perry401 Building & Construction 4 04-25-2011 11:58 PM
Flood/Drainage Issue On Garage Man Door altc81 Building & Construction 2 04-17-2011 08:19 AM
