Old 05-06-2007, 04:55 PM   #1
Default Garage Door Opener
I have an 8X 7 and a 16X7 garage doors to be installed soon - the installer states that I don't need but a 1/2 hp opener ( I had wantred to put in a 3/4 Chamberlian belt drive opener).
He states that the 3/4 hp opener (which has the standard battery backup) may present more reliability issues bec of the battery backup. Anyone have any experience w/ this garage door opener? And should I go w/ the 1/2 hp opener (cost difference is only $30)?
Burat is offline   Reply With Quote
Old 05-06-2007, 05:54 PM   #2
Do not know anything about the brands but a 1/2 horse is enough power. Both doors when installed correctly will take the same amount of force to open. Thanks to the torsion spring. However you should get what you want not what the contractor wants you to have ( in my opinion anyway)
warnerww is offline   Reply With Quote
Old 05-06-2007, 07:43 PM   #3
The garage door opener HP has nothing to do with the doors ability to go up or down. The doors weight is counter balanced by the springs. If the opener had to lift it under it's own steam, it would need alot more then 3/4 HP.
If you look at these openers, you will see that the higher the HP rating, the more options available. 1/2 HP is more then enough.
Ron
Old 05-06-2007, 11:51 PM   #4
General Contractor
joasis's Avatar
My personal choice is always a screw drive operator....smoother, but does require a little maintenance. As stated above, HP means very little in garage door applications, if the door is correctly installed. We just installed a 16 high by 24 wide insulated door, very, very heavy. 4 - 6 inch diameter by 4 feet long torsion springs, and the operator horsepower is only 3/4. And this is a commercial application.
Ladwig Construction
Hennessey, Oklahoma
405 853 1563
Insulation Services
Oklahoma
405 314 5802
joasis is offline   Reply With Quote
More On This Topic
Hello! This is Ross on behalf of expertvillage.com. That is my kitchen door and it is dark outside, it really doesn’t matter I cannot see the garage door anyhow if it was light out because it is blocked by the wall here. I did have to get up to... Read More »
Caring for your garage door can help you save money in the long run. By periodically doing some simple maintenance work, you can avoid serious problems with your garage door and having to spend large sums of money to replace or fix the problem. Here are... Read More »
Hello! This is Ross on behalf of expertvillage.com. Would you look at that… someone left the garage door open. Honey! You know, this electronic stuff is pretty easy. Can you get someone to close the garage door please… Read More »
Hi this is Jon on behalf of Expert Village in this video clip we would be laying out our shelves. Since we made each opening of our project the exact same size our shelves are all going to be the same in width. As I measure that opening I get 21 13/16... Read More »
Whether you need a garage for your vehicle or extra storage it will be a wise investment for your home. The plans for a garage can be purchased off the Internet instead of using a high priced architect because of the simplicity of the design. If you want... Read More »
New Heated Garage: need help! HardcoreCBR General Discussion 12 05-23-2008 09:34 AM
Converting Carport to Garage viking1974 Building & Construction 2 08-13-2007 12:38 AM
Garage Concrete Ledge for Door Replacement orangewhip Remodeling 0 05-16-2006 01:22 AM
Garage Door Opener - Noisy on Closing ? quantass Electrical 2 02-13-2006 04:09 PM
Garage Concrete Slab...HELP? Aqua-Man Building & Construction 2 06-17-2005 03:11 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
