Garage Door Not Going Down - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-19-2009, 07:38 AM   #1
Garage Door not going down
My Craftsmen garage door goes up perfectly every time with both the remote and the wall unit button. Going down is the problem. It often starts to go down and then goes back up. When I use the mounted remote on the wall it will only go down if I hold the button the entire time. For instance, when I hold the button it will go all the way down, but the second I let go of it, the door will go back up regardless of where it is in its way down.
Anyone have any ideas?
I dont know the model number. I know it's a Craftsmen and about 10-12 years old.
cincycuse is offline   Reply With Quote
Old 02-19-2009, 07:47 AM   #2
the Musigician
DangerMouse's Avatar
sounds to me like the limiter was not adjusted correctly, or has come out of adjustment. do you still have the owner's manual? i know, probably not, but it'd help. there will be a way on the back of the power head to adjust the open and close limit and force. they vary as to how they adjust though, so you may need to post us a pic. the one i installed yesterday, a chain drive 'genie PowerMax', has 'smile' shaped holes on the back that needed a small-headed flathead screwdriver to adjust. it's also possible the closing force button may need adjustment.
DM
Old 02-19-2009, 07:51 AM   #3
OK, thanks. I'll see if it does anything when I adjust. If not, I'll take a picture.
Originally Posted by DangerMouse View Post
sounds to me like the limiter was not adjusted correctly, or has come out of adjustment. do you still have the owner's manual? i know, probably not, but it'd help. there will be a way on the back of the power head to adjust the open and close limit and force. they vary as to how they adjust though, so you may need to post us a pic. the one i installed yesterday, a chain drive 'genie intellicode', has 'smile' shaped holes on the back that needed a small-headed flathead screwdriver to adjust. it's also possible the closing force button may need adjustment.
DM
Old 02-19-2009, 09:55 AM   #4
Custom Cabinet Maker
first check the electric eyes are not blocked or out of alignment, there is a indicator light on them that should be on at all times also, if you dont see that check the wiring, re adjust em then see if problem went away
skymaster is offline   Reply With Quote
Old 02-19-2009, 10:13 AM   #5
Enormous Member
skipjack's Avatar
Rewards Points: 87
I'm voting for the limiter too... but check the rollers and the track also. Pull the trolley release and open and close the door manually and see if you can feel any resistance. This is a good way to check the door's balance.... it should open and close fairly easily with one hand.
Openers don't particularly care if something is obstructing them on the way up... but there might be a roller sticking or something on the track causing some friction on the way down... enough of it anyway to cause the opener to think it's bumped into something.
Let us know what you find out.
skipjack is offline   Reply With Quote
Old 02-19-2009, 10:39 AM   #6
SDC
SDC's Avatar
good post...
SDC is offline   Reply With Quote
Old 02-19-2009, 10:47 AM   #7
the Musigician
might help too if we knew what type it is, chain/screw/belt drive.
if chain, the chain might be dragging, making it feel "resistance" and reversing. easy enough to adjust that too.
although the noise it would make would let you know...... *grin*
DM
Old 02-19-2009, 04:35 PM   #8
Good info posted above.
Reversing action is a built-in function when the door hits an object or the elecrtic eye see's an obstruction ... or the door opener is having to push to hard to close. There is a pressure or clutch adjustment on the side of the opener (a screw) that can be turned to increase or decrease the pressure exerted by the motor.
If it was working fine before then something happened to make the opener work harder upon closing. As mentioned, diconnect the door from the opener by pulling the red cord and try the door manually. If you have a broken spring/roller/hinge you'll know pretty quick.
I wouldn't try any adjustment until you are certain there are no other problems. After all, it did work fine the way it was before.
Just my 2
Shamus
Shamus is offline   Reply With Quote
Old 02-19-2009, 05:02 PM   #9
Rewards Points: 184
DM
On mine the limitor is on the side, you have to take the light off to get to it, and its an actual dial you can turn.
abefroman is offline   Reply With Quote
Old 02-19-2009, 05:26 PM   #10
the Musigician
yup abe, they vary as to location as well as style. you still fighting with yours?
DM
Old 02-19-2009, 09:27 PM   #11
what's with all the garage doors going haywire on this forum? I should start a topic of "My garage door won't make me breakfast"
dhag is offline   Reply With Quote
Old 02-19-2009, 09:30 PM   #12
Rewards Points: 184
DM
Yup, the bad thing its its 11deg outside and I have a detached garage.
Garage Wiring issues jimmyfloyd Electrical 20 06-08-2009 02:57 PM
Mold in detached garage jkrodger Building & Construction 15 05-01-2009 01:46 PM
Garage ceiling and attic storage DIY KEN Building & Construction 7 01-06-2009 04:57 PM
Garage Door Install marly General DIY Discussions 2 11-17-2008 02:51 PM
