Old 03-27-2009, 06:37 AM   #1
Tool Geek
PaliBob's Avatar
Post
Garage Door Insulation
Garage door is a metal sectional roll up door in a concrete structure. Floor walls and ceiling are below grade in a concrete Condo building where each unit has their own two car garage opening out to a common area that is open to the street via a common ramp. On cold nights the winds howl through a poorly fitting garage door.
How to insulate around the top, sides, & bottom of the 16ft roll up door?
From the outside the 16' garage door has no visible gaps except at the angeled bottom where there is a swale in the concrete floor that leaves a 2 ½” gap at the center. The sides and top have a 1 to 1 ½” gap at a right angle to the opening.
Rubber strips cannot be nailed to the metal door or to the concrete. Any Ideas without nailing?
& Stay Safe
.....Bob Lavery
Old 03-27-2009, 07:02 AM   #2
There are vinyl moldings with soft viyl strips molded in, available at big box, lumberyards, that will close in that gap. The soft viyl wipes against the door and conforms to the shape.
Old 03-27-2009, 07:10 AM   #3
They sell perimeter weatherstripping for garages. Stores like Home Depot have them. They are a wood textured 1x3" polyboard with a rubber gasketing material attached. You nail it to the exterior frame to seal out the weather. You might need to adjust the top rollers to get the door closer to the frame. If the top rollers on yours are not adjustable, you can pick up replacements and switch them over.
For the bottom, contact the door manufacturer and see if they sell an oversized gasket for the lower section.
Ron
Old 03-27-2009, 03:51 PM   #4
Tool Geek
PaliBob's Avatar
Thanks for the tips. You've given me some ideas to check out.
I can't use nails because the jambs are concrete amd the door is metal.
& Stay Safe
.....Bob Lavery
Old 03-27-2009, 04:05 PM   #5
Xtreme DIY'r
There is an inexpenive tool for nailing into concrete
Powder charges - like a small .22 cal drive the nail in
Lowes & HD carries them
Tags
garage door insulation
Garage Wiring issues jimmyfloyd Electrical 20 06-08-2009 03:57 PM
Mold in detached garage jkrodger Building & Construction 15 05-01-2009 02:46 PM
Garage ceiling and attic storage DIY KEN Building & Construction 7 01-06-2009 05:57 PM
Garage Door Install marly General Discussion 2 11-17-2008 03:51 PM
