#1 |
Garage door insulation
I'm in Houston ready to get garage doors for a newly constructed house and wondering if it's worth getting insulated garage doors. The doors are south facing so not too much direct sun, there is a bonus room above the garage, I'll insulate all the walls and the east wall is connected to the house. Can anyone comment on wheter it's worth $430 more to get insulated garage doors? The one's I'm looking at are rated at R6.84.
Thanks in advance, Stan. |
#2 |
General Contractor
If you plan on conditioning the space (heating or air), then by all means...otherwise, there would be no advantage.
Ladwig Construction
Hennessey, Oklahoma 405 853 1563 |
#3 |
Thanks for the reply. I'm not planning on conditioning it but since I plan to insulate the walls before sheetrock I was wondering if it'd be worth doing the doors too. I've never known anyone with insulated doors around here so I didn't know if it keeps the garage that much cooler (or warmer) without a/c.
#4 |
As a temporary (could be permanent.....) solution, I used foam board and fit it between the lips of each garage door panel. I wedged it in the bottom lip, then bowed it slightly to allow it to "pop" into the upper lip of each panel.
Much cheaper solution for my needs.
I ask the stupid questions.....but I expect the smart answers. |
#5 |
One reason I went with the insulated doors is because it offers a little bit of impact protection from the inside.
#6 | |
Garage door insulationQuote:
in your opinion, did that help? i was thinking about doing that in my garage (i have some workout equipment in there). sorry didn't mean to hijack |
#7 |
I ended up getting the insulated doors and i'm happy with them. The installers put the insulation in regular doors. It came in boxes and they bowed it out and popped it in place. Nothing special other than it was cut to fit properly. Next time I will put a double layer of the foam board insulation and save some money.
#8 | |
I'm not sure what the actual result was. I did it right after we moved in, and I insulated the outer walls that weren't yet finished at the same time.I had nothing to compare it to, since I did it right after moving in. I'm originally from the Mid-West, so insulation just makes sense to me. I figure it is dampening some of the noise I make in the garage, but only my neighbors would know that.
#9 | |
| Display Modes | |
| Mold in detached garage | jkrodger | Building & Construction | 15 | 05-01-2009 02:46 PM |
| double car garage slightly uneven... | mcvane | Building & Construction | 6 | 11-25-2007 09:41 AM |
| Crazy Garage Extension, Building over blacktop?!?! | commissure | General Discussion | 4 | 09-13-2007 12:09 PM |
