Garage Door Header Sag - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-29-2013, 09:14 AM   #1
Rewards Points: 240
garage door header sag
my 4y/o garage has 3 2x12 boards for the 18' door header. it looks like it is sagging just a little. i have not straight edged it, but it looks to be about 1/4"ish.
is this normal and what would be a max ?
if i did need to do something about it, what would i do ?
Fix'n it is offline   Reply With Quote
Old 06-29-2013, 09:36 AM   #2
firehawkmph's Avatar
Rewards Points: 1,922
Fixinit,
run a string on it and see how much it actually is. Pull the string tight. 1/4" in 18' I wouldn't worry about as long as it doesn't continue to get worse. Could have been that way from the start. I usually use engineered lumber for load bearing garage door headers over 14'.
Mike Hawkins
firehawkmph is offline   Reply With Quote
Old 06-29-2013, 09:36 AM   #3
GBrackins's Avatar
Rewards Points: 2,108
all solid sawn lumber will have sag/deflection, even under it's own weight. what is the header supporting?
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
Old 06-29-2013, 09:55 AM   #4
Rewards Points: 240
the garage was a main reason i bought this house. and the sag doesn't seem bad, but i do notice it if i look for it.
it is sawn lumber, pro built garage.
just the hip roof.
Old 06-29-2013, 11:38 AM   #5
Framing Contractor
Rewards Points: 126
1/2" in 20' is probably the max allowable in that situation. You should be fine with 1/4"
sixeightten is offline   Reply With Quote
Old 06-29-2013, 12:52 PM   #6
Civil Engineer
Rewards Points: 4,940
Deflection is normally presented as the length/sag ratio, making sure the units are the same. So if you really have 1/4 inch in 18 feet, the deflection ratio is (18*12)/.25= 864. Typical maximum allowable deflection ratio for a header is 240, so that would be fine. At 1/2 inch deflection, the ratio would be about 430, still OK. So as previously noted, you need to run a string line to measure the actual deflection, your eye is simply not accurate enough.
Daniel Holzman is online now   Reply With Quote
Adding subpanel to Garage jimmyfloyd Electrical 2 11-09-2012 09:22 AM
Garage Roof Support & 2nd Floor Addition Info? olimits7 Building & Construction 3 10-15-2012 06:42 PM
Junction box feeding power to garage from house gmbojanowski23 Electrical 4 10-02-2012 10:20 AM
Expanding Garage INTO house (goodbye Den) texaopian Building & Construction 16 11-07-2011 10:32 PM
