Garage Door Header - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-26-2010, 10:42 PM   #1
Garage door header
Would like opinions on the size of header beam needed for a 10' wide garage door on the gable end of the building. Since there is very little weight on this end, my thoughts are 2- 2x8's. Thoughts anyone?
bushmoose is offline   Reply With Quote
Old 11-26-2010, 10:58 PM   #2
remodeling pro
IMO use 2 x 12's . You are only talking about a few $ more for the 2 pieces of wood, and there is nothing more eye catching than a sagging garage door opening a few years down the road.
troubleseeker is offline   Reply With Quote
Old 11-26-2010, 11:13 PM   #3
Send a message via MSN to reality
Need a little more information. What is on the outside of the garage? What is the pitch of the roof? What is the total span of the garage?
reality is offline   Reply With Quote
Old 11-26-2010, 11:21 PM   #4
Framing Contractor
Why does that matter, it's on the gable end.
Joe Carola
Joe Carola is offline   Reply With Quote
The Following User Says Thank You to Joe Carola For This Useful Post:
mae-ling (06-16-2015)
Old 11-26-2010, 11:35 PM   #5
The building is 22'x30'. all lumber is rough sawn with 7/16 osb sheathing on the outside. Vinyl siding next spring. 2"x6" walls and the roof is going to be 5/12 pitch 2x4 trusses
Old 11-27-2010, 01:27 PM   #6
Is there any snow load to consider for your roof?
Really though, the gable end of the roof generally supports itself so you shouldn't get much of a load on that door. But. . . I'd still do better than 2-2x8's and go 2-2x10's.
househugger is offline   Reply With Quote
The Following User Says Thank You to househugger For This Useful Post:
bushmoose (11-27-2010)
Old 11-27-2010, 04:52 PM   #7
Pro
my opinion is: get it engineered, seriously...you don't know the loads, a gable puts the load downward, not outward, 2x8...way way too small
DarKarvin is offline   Reply With Quote
The Following User Says Thank You to DarKarvin For This Useful Post:
Old 11-27-2010, 08:06 PM   #8
Registered User
Rewards Points: 4,924
IF the gable rafters are continuous and without any notches for the look-outs (out-riggers), the header would only support the wall framing above. With notches = the gable roof overhang loads and the gable rafter PARTIAL load. Very hard to figure as the fly rafter load would counter weight the second rafter in's up-lift, pivoting on the gable rafter. The pertinent question is- Are the overhang framing blocks on edge, bearing on the wall or laying flat, notched into the gable rafter?
1- 2x6x10' span of Doug/Fir N. fb1700# will carry 730# or 73# per foot.
2-2x6 will carry 1400#= 140#per ft.
2-2x8 carry 2450#= 245#per ft. With a 2 foot overhang and 50#snow load, 25# dead load= 75# X 3' = 225# load That is figuring the wall is carrying the full overhang (2') and the 1' inside load from gable wall. Worst case load, no gable rafter. Don't know your snow load.....
Gary
The Following User Says Thank You to Gary in WA For This Useful Post:
Old 11-27-2010, 09:55 PM   #9
Gary
Now there's an intelligent answer!
Old 06-16-2015, 12:21 PM   #10
Rewards Points: 2
i think no one uderstands,
as i see it the gable end of the roof needs no support at all
it supports it self the entier span does it not?
spitze is offline   Reply With Quote
Old 06-16-2015, 01:28 PM   #11
Rewards Points: 144
WRONG Listen to the experts.
mako1 is offline   Reply With Quote
Old 06-16-2015, 02:18 PM   #12
Gymschu's Avatar
Rewards Points: 240
Pictures would go a long way toward giving better answers.
Giving us your general location helps us better help you!
The Following User Says Thank You to Gymschu For This Useful Post:
Fix'n it (06-16-2015)
Old 06-16-2015, 09:46 PM   #13
Msradell's Avatar
Rewards Points: 90
Guys you need to look at the date of the original posts in this thread, they were for a half years ago! I'm sure the problem has either been corrected or have fallen down since then!
Written using Dragon Naturally Speaking
Msradell is offline   Reply With Quote
The Following User Says Thank You to Msradell For This Useful Post:
AndyGump (06-17-2015)
Weatherproofing garage help Perfik Building & Construction 2 10-17-2012 04:30 PM
The 12-Gauge Garage Jack Olsen Project Showcase 28 07-08-2012 11:21 PM
Raising up my garage jimmyfloyd Building & Construction 5 09-17-2009 11:39 PM
Garage Wiring issues jimmyfloyd Electrical 20 06-08-2009 03:57 PM
new double garage murray1426 Building & Construction 4 05-23-2009 02:11 PM
