Garage Door Header - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-03-2012, 05:50 PM   #1
Garage door header
I am spanning a 16' garage door. I have together the equivalent of two 2x12's. My trusses will be 24 oc. Is this sufficient support in the header
cardsman is offline   Reply With Quote
Old 03-03-2012, 06:16 PM   #2
Been Building since 1970
Not even enough info for a guess.
claymcc is offline   Reply With Quote
Old 03-03-2012, 06:23 PM   #3
Rewards Points: 2,210
What is the span of the trusses?
mae-ling is offline   Reply With Quote
Old 03-03-2012, 07:26 PM   #4
Civil Engineer
Rewards Points: 4,566
This is a pretty typical question on this forum, you are looking for a design for a structural member. I don't size structural elements over the internet, but in case you find someone who is willing to do it, this is the information you MUST furnish to them in order to get a realistic answer:
1. The total load that the header will support. This comes from a detailed plan showing the tributary area the header will support, multiplied by the code mandated load per square foot for the tributary area, which for a garage may include floor loading plus roof loading.
2. The clear span of the header.
3. Any point loads the header must support in addition to the distributed load.
4. Detailed information regarding the foundation support available on both ends of the header, since the header almost certainly will be supported by king and jack studs.
Daniel Holzman is online now   Reply With Quote
Old 03-03-2012, 09:34 PM   #5
firehawkmph's Avatar
Rewards Points: 1,822
What exactly do you have for the equivalent? (2) 2 x 12's are (2) 2 x 12's. Go to your local lumberyard with your prints (?) and they will size it for you.
Mike Hawkins
firehawkmph is offline   Reply With Quote
The Following User Says Thank You to firehawkmph For This Useful Post:
BigJim (03-05-2012)
Old 03-04-2012, 09:00 AM   #6
Structural Engineer
Try to do a Goggle search for "How to determine the size of a garage header". There are numerous charts that give header sizes if you know the load and span and type of wood. Check 10 different websites or more and you will hopefully get a consensus of what the size should be. Like has been said, the internet design method is not the best way to go. But if you get the same answer from 10 websites, it may be close to the correct answer.
House Engineer is offline   Reply With Quote
Old 03-04-2012, 10:35 AM   #7
JOATMON
ddawg16's Avatar
Rewards Points: 1,116
I have a 14' door in my 20x25 garage....
THAT header is a PSL beam....7.25"w x 11.25" tall.
In the old days...a couple of 2x12's as you noted was sort of the norm....easy to spot them....they are the ones sagging in the middle...
If you click on the Garage Build link in my sig, one of the pics is of the garage header.
Old 03-04-2012, 10:52 AM   #8
Rewards Points: 2,238
"cardsman"
Built a garage, last Fall.
Header - (2), 2 X 14 (nominal), "Micro-Lams" -
"Bolted", together.
Our "codes" may be different than yours!
rossfingal
(Also - what "Daniel Holzman" and "ddawg16" - say!)
rossfingal is offline   Reply With Quote
The Following User Says Thank You to rossfingal For This Useful Post:
BigJim (03-05-2012)
Old 03-04-2012, 11:20 PM   #9
remodeling pro
Not in my opinion, even without questioning the posibility of how much load it may be carrying. Even with no load, it will have a very noticeable sag within a couple of years. This is a job for an engineered product like a LamBeam or steel. Check out a product called LiteSteelBeam, sometimes referred to as LSB.
Whatever you use, take to heart the suggestions of other posters that anyone who gives you serious structural advice in a forum like this is best ignored. Every structural design is specific.
troubleseeker is offline   Reply With Quote
Expanding Garage INTO house (goodbye Den) texaopian Building & Construction 16 11-07-2011 11:32 PM
Garage Insulation yamster Insulation 0 07-01-2011 02:30 PM
Do I have a Fire Rating Issues with Attached Garage Perry401 Building & Construction 4 04-26-2011 12:58 AM
Garage Wiring issues jimmyfloyd Electrical 20 06-08-2009 03:57 PM
