Garage Door Framing Question - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-26-2012, 12:23 PM   #1
Hi All,
We're in the process of having a house built and have a question regarding framing of the garage door openings.
The sill plates for the right side of the garage door were laid flush with the edge of the foundation slab. The sill plates for the left side of the garage door extend about 1-inch over the edge of the foundation.
Assuming the foundation edge is straight, will the 1-inch mismatch create problems with the installation of the garage door (or operation of the garage door)? How much misalignment is tolerable? Assuming the framing is already complete, what can be done to correct the misalignment?
Thanks in advance for your responses.
Jim
haganjp is offline   Reply With Quote
Old 09-26-2012, 02:06 PM   #2
Rewards Points: 150
Depending on the stage of the building process, my guess is that the builder will straighten this overhang out before completing the exterior work (i.e. siding).
How is the rest of house coming along? I would be concerned if everything else are "miss aligned" like what you show in the photo.
I don't know about everyone else, but photos are always good for discussions...
oodssoo is offline   Reply With Quote
Old 09-26-2012, 02:40 PM   #3
Rewards Points: 2,212
I'd ask your builder.
Can you show pics of both sides, and then the whole front?
Although if it is left this way it will surely be noticeable.
mae-ling is offline   Reply With Quote
Old 09-26-2012, 05:17 PM   #4
Rewards Points: 13,732
Not only is it misalighen but there is no row of block laid so the siding will be sitting right at grade judging by that picture.
By code the siding needs to be at least 6" above grade
Old 09-26-2012, 05:25 PM   #5
Joe not sure where the poster is from that is not code everywhere. Although not a bad idea.
Old 09-26-2012, 05:36 PM   #6
GBrackins's Avatar
Rewards Points: 2,108
I'm curious where the two anchor bolts per section of sill plate are, but then again they may not have any code requirements ....
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
Old 09-26-2012, 06:18 PM   #7
To me it looks like it is all studs to the corner.
Old 09-26-2012, 06:24 PM   #8
GBrackins's Avatar
I agree mae-ling ...... I would ask my builder about any anchor bolt requirements for attachment of the sill plate. again, maybe they do not have a requirement for such (doubtful though)
Gary
Old 09-26-2012, 11:02 PM   #9
It's the front side of the garage. The grade hasn't been dugout for the installation of concrete I'm guessing. I think that it's over hanging the concrete because the foundation is slightly out of square. Bummer but not really a problem.
check what's square,
tham
Tham is offline   Reply With Quote
The Following User Says Thank You to Tham For This Useful Post:
woodworkbykirk (09-27-2012)
Old 09-27-2012, 12:15 AM   #10
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,212
i was thinking the same thing. its no big deal if the plate overhangs a little bit to keep the walls square to one another.. its really common for a framing crew to show up to foundations that out of square by a small amount.
as long as no more than 1/3 of the plate stock overhangs its within code. and judging by hte photo you cant tell where the anchor bolt is, it could have been kept back so its not into the door opening. if your really concerned about it just pick up a 1/2"x 8" concrete wedge anchor. it has to be atleast 5" into the concrete to ensure it doesnt pull out . ramset pins dont count either
woodworkbykirk is offline   Reply With Quote
Old 09-27-2012, 08:08 AM   #11
AHH, SPANS!!!
Rewards Points: 1,166
that 1" overhang should not be a problem as long as its bolted to the concrete.The sidewalk and garage apron are still to be added to the garage so they will be under the wall overhang. It looks as though the framers need to add in the jacks for the door header also (or cut back the plate) so maybe the bolt will go in before the jacks and header are placed,or maybe the bolt is under the jacks. With the wall hanging out the 1" it needs a bolt near the end of the wall...
hand drive is offline   Reply With Quote
Adding Mudroom in exisiting garage - Foundation question screamon demon Building & Construction 2 02-02-2011 12:30 PM
question about wiring basement with garage panel 1acman Electrical 4 01-19-2011 11:44 AM
Garage Heater Wiring ceiling penetration Question DenverBob Electrical 5 12-28-2009 01:01 PM
Garage insulation question trojanman1 Building & Construction 7 09-16-2009 02:51 PM
Carport to Garage: Fire barrier question Grommet Remodeling 2 03-28-2008 04:18 PM
