Old 07-23-2011, 06:56 AM   #1
Garage door framing
I'm putting up a new garage. (myself?)
Cement is done, 32 x 32 w/12" curb wall all around. (except doorways)
Question: garage door openings were left at 9'6", I expected 9'3"....
Any suggestions how to frame? just double the jamb on each side?
Thanks, Mike
ekimdoog is offline   Reply With Quote
Old 07-23-2011, 08:14 AM   #2
Garage door framing
You'd frame it based on the door size rough opening and close it down to that.
Ron
B. Franklin 1759
Old 07-23-2011, 08:38 AM   #3
old guy contractor
tcleve4911's Avatar
Garage door framing
The 3" difference is usually allowed to have the last framing members go all the way down to the slab so the bottom of your jambs have something to fasten to.
1-1/2" on each side = the 3"
I like to use pressure treated 2x since it will be end grain sitting in a potentially wet area.
tcleve4911 is offline   Reply With Quote
Old 07-23-2011, 10:19 AM   #4
STAFF
BigJim's Avatar
Garage door framing
I usually slope the header piece of the jamb and hold the two legs of the jamb off the floor about 3/8 inch to keep water from wicking into the jamb.
New members: Please consider adding your location to your profile, it helps other members to give more accurate answers to your questions.
Jim
BigJim is offline   Reply With Quote
Old 07-23-2011, 12:17 PM   #5
firehawkmph's Avatar
Garage door framing
In addition to what the others said, the rough opening for your overhead door should end up being the size of the door itself. For example 9'wide by 7' high door should have a rough opening of 9' x 7'. Once you put your finish jambs in and the weatherstrips, you'll have an inch+ overlap onto the door.
Mike Hawkins
firehawkmph is offline   Reply With Quote
Weatherproofing garage help Perfik Building & Construction 2 10-17-2012 04:30 PM
Garage Insulation yamster Insulation 0 07-01-2011 02:30 PM
Do I have a Fire Rating Issues with Attached Garage Perry401 Building & Construction 4 04-26-2011 12:58 AM
Garage Wiring issues jimmyfloyd Electrical 20 06-08-2009 03:57 PM
