Old 03-09-2012, 10:33 AM   #1
Garage door frame slumping.
So I noticed shortly after buying my house that there was a bit of a sag along the top of my garage door frame. It's kind of tricky to spot, but it's definitely there, as evidenced by my gutter sagging and dumping rain water out as well. I had a contractor out to look at quoting me on a new garage door, and he wasn't even interested in the job, stating that it was a major structural problem that would have to be fixed. Here's some pictures-
A couple of theories are that I could get a basement jack and jack the center of that top plate up slowly over a couple of weeks. Shim it up and then pull the drywall down in the garage and brace it somehow.
Another concern was that would simply bandaid the problem and that I would need to tear out the garage door frame, take off the siding and completely start over reframing the front of the garage. Any ideas?
kadetklapp is offline   Reply With Quote
Old 03-09-2012, 12:34 PM   #2
Civil Engineer
Post a picture of the header over the garage door. Also measure the dimensions of the header, and the span of the header. It looks like the garage door header may be directly supporting the roof trusses, possibly the header is undersized.
Old 03-09-2012, 12:35 PM   #3
Architectural Designer
AGWhitehouse's Avatar
The beam across the garage door was either undersized or has become compromised. That beam will need to be replaced. You can do this without a total gut and go, but will surely require a temporary shoring wall, an engineer and his calculations for a new beam size, and an insured contractor to do it...
Life's too short...so enjoy it!
AGWhitehouse is offline   Reply With Quote
Old 03-09-2012, 12:39 PM   #4
Would the header be the frame at the top of the door or is this hidden behind the siding/drywall?
Old 03-09-2012, 01:05 PM   #5
The header is concealed behind the drywall. First step is to remove the drywall and determine what, if anything, is there. Once done post some pics so that informed suggestions can be made.
Marvel is offline   Reply With Quote
Old 03-09-2012, 01:59 PM   #6
JOATMON
ddawg16's Avatar
I'm interested in seeing what that header looks like.....I have a feeling this thread could be the poster child for properly sized headers....especially with the recent spat of header span questions....
Common Sense is like Deodorant. Those that need it the most don't use it.
My
and
ddawg16 is online now   Reply With Quote
Old 03-09-2012, 02:10 PM   #7
Can see it now on the sides of milk cartons:
"Have you seen this header?"
Old 03-09-2012, 02:22 PM   #8
Ok, this picture probably isn't going to make much sense. I had to get right up to it to get a picture of it. The transparency of the garage door had full sun shining thru and made it impossible to get a shot from further back. If you can't see anything I'll take a picture after dark-
Old 03-09-2012, 02:22 PM   #9
Not so new
12penny's Avatar
Gonna fix the light?
12penny is offline   Reply With Quote
Old 03-09-2012, 02:24 PM   #10
LOL, I wondered when someone would say something. We had a bout of wind here recently and who knew, but you are supposed to use a box behind those...
Old 03-09-2012, 02:26 PM   #11
Not so new
12penny's Avatar
See if you can determine what makes up the header. How many plys? Is that 2x10 in the bad picture?
Old 03-09-2012, 02:30 PM   #12
It is a 2x10 mounted on it's side the length of the door frame. There is a 2x4 laying flat on top of it. I cannot tell how many 2x10s there are, I suspect one.
Old 03-09-2012, 02:34 PM   #13
Here's a professionally detailed graphic image....
Old 03-09-2012, 02:36 PM   #14
Not so new
12penny's Avatar
If there a 2x4's on top its probably 2-2x10 and some 1/2" plywood. I'd guess a little light for the span.
Someone with more/any engineering experience will be along soon with their thoughts.
Old 03-09-2012, 03:00 PM   #15
Civil Engineer
I suspect 12 penny is correct, although I would not bet my last dollar on the plywood. You need to determine how many 2x10s there are, and if there is a filler piece such as plywood between the 2x10s. Also, measure the 2x10 to determine the exact height of the 2x10, typically they are 9-1/4 inches, but there is some variation.
Expanding Garage INTO house (goodbye Den) texaopian Building & Construction 16 11-07-2011 11:32 PM
Garage Insulation yamster Insulation 0 07-01-2011 02:30 PM
Do I have a Fire Rating Issues with Attached Garage Perry401 Building & Construction 4 04-26-2011 12:58 AM
Garage Wiring issues jimmyfloyd Electrical 20 06-08-2009 03:57 PM
