Garage Door Falls - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-11-2011, 02:31 PM   #1
Garage door falls
My garage door goes up and after it raises about 2 foot it will shut off and fall down. You have to hold the button down to get it all the way up. Once up the cable is loose around the spring end. I have a spring rod (inclosed) system for a 16 foot wide door.
Thomas
Thomas12 is offline   Reply With Quote
Old 04-11-2011, 02:48 PM   #2
Rewards Points: 1,596
Not sure I understand fully, but your spring could be broken. The opener is not really designed to lift the door without an assist from the door spring system.
bob22 is offline   Reply With Quote
The Following User Says Thank You to bob22 For This Useful Post:
Thomas12 (04-11-2011)
Old 04-11-2011, 03:41 PM   #3
MikeKy55's Avatar
Rewards Points: 254
Bob22 is right. The opener is not designed for lifting alone. It's very possible doing that will strip the gears in the opener.
MikeKy55 is offline   Reply With Quote
Old 04-11-2011, 04:35 PM   #4
That is what I was thinking, I'm going to try to adjust the spring and see what happens. I fell down closed like the motor just gave up.
Old 04-11-2011, 05:08 PM   #5
It that is a torsion spring (usually mounted on the wall above the door) do not attempt this. There is a tremendous amount of energy in that spring and if you do it wrong, you could get seriously injured or killed.
Old 04-11-2011, 08:22 PM   #6
Yep! If you have never adjusted a torsion spring call a pro. He can do it safely and in probably 1/10th time it will take you just to find out you didn't really want to mess with it.
Mike in Arkansas is offline   Reply With Quote
Weatherproofing garage help Perfik Building & Construction 2 10-17-2012 03:30 PM
The 12-Gauge Garage Jack Olsen Project Showcase 28 07-08-2012 10:21 PM
Raising up my garage jimmyfloyd Building & Construction 5 09-17-2009 10:39 PM
Garage Wiring issues jimmyfloyd Electrical 20 06-08-2009 02:57 PM
