Garage Door Dented - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-09-2010, 10:08 AM   #1
Garage door dented
I backed into my garage door. the frame & track do not seem to be bent. it opens & closes also. It appears the panels are just dented in a bit. Do I have to replace the entire door or can I just replace the panels?
redd1996 is offline   Reply With Quote
Old 09-09-2010, 10:14 AM   #2
redd1996
Well my husband says it opens & closes but not smoothly. do i have to replace the entire door?
Old 09-09-2010, 10:31 AM   #3
Rewards Points: 558
If itís a metal garage door you can repair the panel by using body filler the same stuff you would use for your car apply it, sand it, prime it and paint it. If itís a wood door you can use wood filler depending how big the dent is. Or if you wish you can just remove the panel and replace with new unless your handy you can do it yourself if not, call a garage door company and also have them look at your door not opening and closing properly. It would probably need to be adjusted but no need to replace the door.
epson is offline   Reply With Quote
Old 09-09-2010, 10:57 AM   #4
thank you. I hope to just replace the panels. we'll see
The 12-Gauge Garage Jack Olsen Project Showcase 28 07-08-2012 10:21 PM
Garage Insulation DIYguy2000 Building & Construction 2 12-09-2009 07:41 AM
Raising up my garage jimmyfloyd Building & Construction 5 09-17-2009 10:39 PM
Garage Wiring issues jimmyfloyd Electrical 20 06-08-2009 02:57 PM
Garage ceiling and attic storage DIY KEN Building & Construction 7 01-06-2009 04:57 PM
